Looks awesome! It seems as though you picked an excellent detail oriented shop Andrew. Unusual to see things like the door jams painted! Can't wait to see it when it is all done!
Somehow I don't think AL will be ready for a timely birthday present, unless this is 2018's present.  IIRC your 2017 birthday coincides with our Presidential Inauguration.  So Happy Birthday.
When you take AL up for the first few flights, stay out of heavy rain.  The paint may still be curing for some time, and you don't want to damage your leading edge paint.  I speak from experience.
She is really shaping up. I like the idea of painting the landing gear white, I'm not crazy about schemes in which the gear is the same as the contrasting color.
Edited by flyboy0681
2 hours ago, cnoe said:
I'm pretty sure that's not a $10AMU paint job. Very nice!
Oh definitely not 10amus. But then she will be sorted when she comes out and as good as new
This is true Neil.  But APD has decided to take me to Helsinki as a commiseration present so I am spending Friday in a wood fired sauna and spa complex.  Heaven.
Gear is white.  Gear doors will match the wing underwing colour. (Secret at this stage. )
AL has been down for a while and I imagine you haven't been flying since. Our recent overhaul kept the Mooney out of commission for a full three months and in that time I hadn't flown at all, until last weekend. When they say rust builds up quickly they aren't kidding. If you have the ability to rent or go up in a friends plane, I would highly suggest you do in order to stay current.
Can I assume that when you pick her up that you will be taking an instructor with you?
Well I have flown, but in a 152 (power ratio = wet fart), landings and the flight were perfect albeit DAMN slow, you cross the threshold at WHAT speed?
I will share with you all my plan:-
  • Engineer will put plane back together
  • Flight test pilot (Seppe use the same one every time) will put 5 hours on the aircraft (my figure, theirs was less) to make sure everything as far as he is concerned works, flight controls, gear, radios, AP, engine Ts & Ps etc.
  • I will test fly aircraft afterwards, with him in right hand seat, do about 2-3 hours to get comfortable again, then my co -owner will do the same.
  • Then if all OK we shall fly her home.
Andrew
Andrew,
Will they be throwing in a few pairs of these for you?
6 minutes ago, M20Doc said:
Andrew,
More likely this..
Nice that they are doing that first flight too. After my paint job totally mis rigged and guess who found out. :)- me
7 hours ago, M20Doc said:
Andrew,
Oh god NOOOOOOO.   My dad had some and swore by them but sorry not for me.  Some cheese perhaps. :)
My scariest flight was with a Pitts s1s right out of paint shop...required 3/4 left stick for level flight...ran off into the grass at the mountain strip on a plateau....no real damage but I did wack a taxi light while going off the runway...Took something like 7 washers under interplane struts to get correct...anyone who has flown a PiTT Special knows what it is like to land one and how it felt to land one so out of trim.
  • 2 weeks later...
Almost there.  I have a date (sort of) now 14th Feb. My baby comes back to me on Valentine's Day.
The fuselage has been painted and they were applying the masking decals.  I went there with Craig Barnett of Scheme Designers who did the scheme.  He poured his eagle eye over everything and seemed very content.
before decals
close up of pearly paint
masking decals
masking decals
"da man" doing the decals.
By mistake they painted the pucks so had to replace them. This is what they looked like when removed.  These "passed" the last annual. God knows how!
Andrew
Andrew were the pucks protected from stripper? Looks like they got eaten.
yes they were all bagged up.  (so i assume they were)
That surface corrosion on the puck plates is pretty common but it is the rubber compound breaking down the issue.Lots of threads here on MS as to when to replace but they could have passed last annual per the 100 pt inspection manual
I am glad the pucks got replaced, she is sitting a lot higher now. :)   But to be honest, i just cant wait to get her home.  Seeing the paint go on at last has made me slightly impatient.
There is a large uk fly in on the 26th feb that i want to go to.  Something like 50 planes are coming so it should be great.
2 hours ago, M20Doc said:
A Mooney?
Nope its a trans sexual Commanche who has decided he has always wanted to be a she Mooney. :).  Sorry Clarence i couldnt resist.
You can tell it's a Mooney, it has an itty bitty engine.
Looks like a great shop! Make sure to get a gear swing done before flight to check the rigging. It *is* possible for a paint ship to rig nose gear doors with the hinges backwards.
Sent from my VS985 4G using Tapatalk
