There should be a new weight and balance with most major alterations.  I would check with those files.  They are typically provided with the 337.  If you can't find that, ask the last shop that did a mod. On your aircraft.  Is this aircraft new to you?  I have blank sheets, but as Alex said, you need to baseline it.
In the mid 60s the WnB data wasn't an FAA standard in the POH yet.... The Mooney factory outlined all the details on a loose piece of paper that is probably kept with your airplane's logs.
I happened to find mine for the 65C while searching through the logs, didn't realize the piece of paper that had so much detail was the official document.
The most up to date POH is probably 1977 for the E.  Contact the factory to get a copy...
Download the app Aviation Weight & Balance...you'll be able to choose from a number of makes/models, including the M20E! Check that against whatever info is sent your way. And then, you can use the app--which is remarkably handy.
