They would be November '66, certain don't owe anyone anything.  I would be prepared for some corroded parts once the discs are removed from the spindle.
Yep-  My biscuits were '68 original when I bought my plane, so I decided to spring to have them changed out immediately after pre-buy. This led to more expense replacing corroded parts found when pulling apart the gear.
You can order overhauled spindles/towers now from LASAR whom rebuilds them for considerably less than new. Yours will most certainly be rusted inside the bottom of tube from where water collects.
mind if I ask approximately what they cost? feel free to PM it to me if you prefer.  thanks!
3 minutes ago, Hector said:
The biscuits are about $100 each.
right, that I was able to find online pretty easily but I'm trying to find the entire landing gear unit, mains and nose, if they need to be replaced/overhauled which if you ask me, they do.
3 minutes ago, Hector said: The biscuits are about $100 each.
Sorry, I don't have that cost data but call Lasar and they can tell you. Look up their website and they list the phone numbers for the parts department. Take it all off first then clean and inspect. Surface corrosion can be removed. I would also measure for wear and excessive play at all attachment/pivot points, then you will know what needs to be replaced.
Looked at my invoices, but hard to predict what it will be for you.  The biscuits themselves were 1.2 amu all together as noted above.  My big ticket item was then a new nose gear spindle assembly for another 1.1 Amu.  Then I needed assorted bearings, races, nuts, bushings, and spacers replaced on the nose and mains- these were small but numerous items which added up to several hundred for the parts.  26 hours total charged on the labor.
I had called Dan to price it new towers if I were to need them when I replaced biscuits this summer.  This was for the mains only, but I think I have a folder with the quoted price.  Threy had them in stock then.
I'll see if I can dig up the part numbers and prices.
