Hi all,
My aircraft will shortly be coming out of its annual maintenance, with no bad suprise has I take very good care of it.
However, my maintenance store wants to replace my fuel selector valve as per the manufacturer maintenance manual (aircraft serial#24-0975). The fuel selector is an Anderson-Brass type which apparently has a potential of 500 hrs. Passed that time, it needs to be replaced for the price of €1500,00 ($2000) - not including labor !!! - Sounds enormous and before going any further, I just want to get some kind of confirmation from you guys that this part needs to be replaced.
How much this fuel selector sells for in the USA ?
Is this type of equipement can be overhauled ?
Thanks for your answers.
Philippe
I am waiting to hear from Piloto on this one....
From my experience:
My M20C had 5,000+ hours on its fuel selector.  The fuel selector is a combination of selector valve and water separator / screen / discharge valve.
I am sure the assembly can be expensive to replace, however a few moving parts can be exchanged.  Each year at annual this assembly would be separated cleaned and put back together, without any issues.
I would often find fine rust particles (fill neck detioration - get stainless steel) settled in the bottom of device.
I am not familiar with a required replacement based on hours.
Quote: unicom
Hi all,
Philippe
