does anyone know if this clock can still be purchased from davtron? Or does anyone know of one for sale or where I can even find a used one? ive looked on davtron's site and can't find it. This is not my panel btw. I have the old anolog clock with sweeping hands that has the thin aluminum bezel around it, I just want to replace mine with this style.
Mike
Edited by Mhemperly
Mike
$50 on eBay, looks exactly like yours, just over 1 day left.
http://www.ebay.com/itm/Davtron-M800-Aviation-Chronometer-for-14-volt-system-/321880964417
Or it looks like to get it repaired you just send it straight to Davtron, and the repair is a flat $70.
http://www.davtron.com/support.php
I'm not sure that is his unit. With the exception of the blue buttons, the lettering on the unit is different. It also appears his unit is a flat surface square. The eBay unit looks like a 2 1/2" hole mountable.
This is the full line for the Davtron series. Hard to tell from the pictures if the M802 or M850 might work.
http://www.davtron.com/overview.php#800
thanks marauder. The picture I posted is not my panel. I just like that clock because it fits the yoke without using the thin plate that is used with the anolog clock with the sweeping hands.
Mike
close but not exactly what I'm looking for. The picture I posted is not my panel. I guess I should of specify that in my post. I think davtron use to make a clock specifically for our vintage mooney yoke that eliminates the thin aluminum bezel that goes over the round anolog clock.
Mike
The Davtron 877 fits into my yoke perfectly.  Uses a double A battery, so except for the illumination is completely self contained.
I may have To go this route if I can't find the square one that fits perfect with just the two screws at each corner
mike
