I found a switch. Does anyone know if the gear override that is in newer Mooney's can be added as an STC for a M20E? If so, I may go through the hassle of putting one in.
Have you tested the relay?   I don't have electric gear (because of these kinds of potential problems), but I am pretty sure there should be a relay switch somewhere.  I know someone that had relay switches go bad for his flaps too.
On jacks. If you ever have your plane in for mx, I highly recommend helping pull panels or go and learn about the systems hands on.
Sent from my Galaxy S5 via Tapatalk
