I have an M20E and may in the near future need the two assemblies noted in the title or info on or sources to rebuild same. Your help is always appreciated.
Jonathan Bodine
Faeth Aircraft in Calfornia 916-368-1832 can repair these items very reasonable, cheaper than buying new for sure.
I have two parking brake valves that are in excellent condition.
I would recommend that you NOT rebuild your original senders.  The newer style senders are better, more stable and can be retrofitted to your airplane.  They are mounted identically with the same mouting hardware and footprint. The newer style ones are also impedence driven and the gauges will register them like it did the old ones.   I have two used and rebuilt newer style senders if you are interested.  (see attached pictures)
There are also available options for new individual STC'd electronic fuel gauges to replace the needle fuel gauges as well.
You can e-mail me at johnabreda@yahoo.com or call me at (617) 877-0025.
Thanks,
John Breda
post-8543-0-53402900-1382968559_thumb.jp
post-8543-0-39967900-1382968569_thumb.jp
I went to the Copperstate Fly In on Saturday. (our little Oshkosh) There were two parking brake valves tied together for $25.00 at the Fly Mart. If I knew someone needed one I would have grabed them.
If I recall, replacing the o-rings will make them like brand new.
I have both the parking brake valve $80.00 I have two fuel level sending units the regular one is $125.00 and the new style one is $140.00
email me (heatherlvn@gmail.com) and I will give you my number
thanks
Heather
