Hi Jim. I was looking at the EI Fp5. I can have it installed up here for around 800 Canadian. Not sure if anyone has any feed back on this unit. I will read up on jpi. As well thanks
I bought a used JPI 450 from a forum member doing an upgrade.  It goes in the week of the 29th.
The STC is free from JPI but you have to send them an email and they send it back to you in their reply.
BILL
I have an EI FP5 that I installed in 1995. Still going strong, simple to use and recently was interfaced to my Garmin GTN 650. I have a lot of hours on it and am very happy with it. It also has fuel pressure capability and I can say it reports the digital value of what I see on the Mooney analog gauge accurately. If you have any questions on it, let me know.
I had a EI FP5 and I loved it too. I just changed it when I decided to upgrade to a JPI 830 and I still miss it...
BILL
BILL
Bill has my 450 which worked great. I upgraded to a JPI EDM 930 which permitted me to get rid of about 10 gauges scattered all over the panel but the 450 was extremely accurate. Typically the totalizer matched the fuel pump to 0.1 gallons.
I have the EI FP-5L and am very happy with it.  The JPI has a second line on the display, so it will read the fuel flow constantly, while allowing you to cycle among the other display options on the second line--nice feature, which the EI doesn't have.  OTOH, the JPI uses an LED display, while the EI uses an LCD.  The LCD is clearly visible in direct sunlight; I expect the LEDs would wash out.  The EI also has a very nice, even backlight on the display, so night visibility isn't an issue.
Second to the engine monitor, my fuel flow JPI 450 is the most important instrument on the engine management side.  Connected to my panel GPS it keeps extremely accurate record of fuel to destination, reserves in gls and hrs, etc.   which gives you the confidence to make in-flight decisions to change your intended stop for whatever reason, weather being the most important.    In my previous plane I had installed the EDM 700, combination engine monitor and FF in a single display but in present arrangement since I had the space I kind of like not having to scroll through all the data or flip any switches.  I bought it at Sun & Fun and with the rebate I paid less than $500.  Installation should less than a day and cost depends on your shop's rates.
My panel is full of LEDs (MX170C dual nav/comms, Aerospace Logic EGT and Ammeter/Voltmeter instruments, and the JPI FS450 fuel flow instrument).  I only have one LCD in the form of an Astrotech LC-2 chronometer.  Sunlight visability isn't an issue with any of them, but my J has a large glareshield "eyebrow" that very effectively shades the instruments.  YMMV.
To me the EI FP-5L and the JPI FS-450 are the only games in town for basic digital fuel flow instrumentation, and which one you choose comes down to personal preference.  I chose the FS-450 because it was the cheapest at the time, and because it fit in best with my already LED-dominated panel.
Jim
Both the JPI FS450 and EI FP-5L are currently about $500 to $530 at retailers like Aircraft Spruce and Chief.  Spruce offer free shipping on orders over $500. I just got a JPI FS450 but it was 50:50 on which one to pick.
  • 1 month later...
Do you currently have an engine monitor?  I would place that higher on the priority list than a fuel totalizer, although both are important and very nice upgrades.  If not, you might consider trying to get a JPI EDM-700 with the fuel flow option and kill two birds with one stone.  I have that and it is wonderful.
If you want to have the FF constantly showing, you can show it on a Garmin GNS screen in one of the customizable fields too, otherwise, it will scroll through the data on the EDM and show it in sequence with the rest of the parameters.
You might consider an Hoskins FT 101 which many of the early Mooney's had. They give fuel flow and total fuel used. I seem to remember putting a used one in a 78 201 and was able to hook it up to the factory transducer. Check in the parts for sale forum. There wear several available.
