carusoam Posted November 4, 2012 Report Posted November 4, 2012 $5 can get you a WnB app for your idevice. This almost completes my migration from laptop to iPad... There may be a way to share the details of settings if anyone is interested in my Ovation details... Best regards, -a-
FloridaMan Posted November 4, 2012 Report Posted November 4, 2012 The WnB Pro App is excellent. I've done my "F" in this as well.
mulro767 Posted November 4, 2012 Report Posted November 4, 2012 Aero Balance works great too. Just add your serial number, BEW and it does the rest! Easy setup.
andrew Posted November 5, 2012 Report Posted November 5, 2012 Does AeroBalance offer anything that WNB Pro doesn't? Just wondering because it looks pretty similar on the surface aside from having a few datapoints pre-entered off the type certificate, but it's 4x the cost. I've been using WNB Pro and am quite happy with it so far.
Hank Posted November 5, 2012 Report Posted November 5, 2012 I found a spreadsheet that figures it, and draws the envelope, free. "Google is your friend." All I did was enter my empty weight & CG, and it did everything else. Now I have another page with various loads for quick reference, and for something unusual I can easily calculate the envelope and adjust loading or fuel as needed.
jetdriven Posted November 15, 2012 Report Posted November 15, 2012 Dont forget your Garmin aera or 296/396/496/696/796 has a weight and balance calculator installed. Enter the BEW and the moment. Then the passengers, gallons of gas, and baggage. It calculates the gross weight and CG for you.
Lood Posted November 16, 2012 Report Posted November 16, 2012 Dont forget your Garmin aera or 296/396/496/696/796 has a weight and balance calculator installed. Enter the BEW and the moment. Then the passengers, gallons of gas, and baggage. It calculates the gross weight and CG for you. That's the interesting part Byron. I have also downloaded quite a couple of nice-to-have apps since I got my iPhone, just to discover that my trusty old G296 cam do it all. Many might even be easier to do on the Garmin in flight.
romair Posted May 24, 2013 Report Posted May 24, 2013 For those of you who use W&B Pro, and also own a J model - where did you get the arm data? My POH does not have any arm data at all. Thanks Stefan '89 M20J
carusoam Posted May 24, 2013 Author Report Posted May 24, 2013 There should be a graph in your POH / W&B section with notes in the graph itself that indicate arm lengths... Front seats, back seats, cargo and hat shelf.... And ranges for anything that moves...(seats) They are pretty well hidden. Fortunately, you only need to find them once. Keep in mind this experience comes from the POH of my '94 O. Ymmv. Best regards, -a-
romair Posted May 25, 2013 Report Posted May 25, 2013 Well, I'm not able to find it...I'm dividing momentums to weights, getting a fairly close estimate...seems that is the only way to do it so far.
Marauder Posted May 25, 2013 Report Posted May 25, 2013 Well, I'm not able to find it...I'm dividing momentums to weights, getting a fairly close estimate...seems that is the only way to do it so far. Is it possible it was a supplement? Mine was not actually in the POH, it was a separate book with the graph and data.
carusoam Posted May 25, 2013 Author Report Posted May 25, 2013 My 65c had an additional page kept with the log books. Every plane is born with a W&B sheet. Modern planes' POH should have any updates for installation and removal of equipment. Weather it's POH or Log book, it needs to be there... Look for where equipment has been added or removed and documented, dates, weights, and arms... Best regards, -a-
