N911TP Posted January 2 Report Posted January 2 Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. Good for them, that’s an excellent problem to have. Wondering if it’s worth the wait or if I should go elsewhere. Local A&P on my airfield can do it for $1500 per wing. Pro: 10 year warranty. Done right the first time. Con: 2 day trip to MN each way plus airlines and hotels. $7500 per wing. 2 year waitlist.
47U Posted January 2 Report Posted January 2 1 hour ago, N911TP said: Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. You know the experience level of your local A&P… but a full strip and reseal of integral tanks is not a job for the faint of heart. There’s a bit of artistry involved if you’re going to get a quality job. I know a former owner who is an A&P and did a full strip and reseal on a ‘64D/C he was resurrecting. He did a great job, but I don’t know if he’d want to do it again. He wasn’t under any time constraints which might be a factor. I’m in NORCAL and made the trip last year at this time. The initial window he gave me was for last March, but he had a cancellation and was able to move me up to January. I didn’t have any leaks that needed attention, but the top coat was showing up as granules in the fuel samples. And it wasn’t getting better. The price he quoted was accurate on my ‘63C, plus he installed the screw-in sump drain service bulletin on the left tank (the right tank had been done during a patch job by the previous owner). And, Paul swapped in some serviceable fuel quantity senders he had on hand taken out of a J model which saved me the cost of sending mine out for overhaul. Both the sump drain and quantity senders were done at no additional charge. I removed the interior side panels before I left so he wouldn’t have to deal with that. I had family travel commitments and he hangared my airplane for me for three weeks before my scheduled date which was the last week in January… until I could come pick up the airplane in March. I have relatives in the area who were able to give me transportation to and from MSP which was a big factor in my decision to travel that far. Paul has a contact that will provide shuttle service at a reasonable rate. I think you’ll have confidence in the final product with Paul. I’d want a specialist for a job that requires this much attention to detail. Your local A&P might do great, but if not, what then? 1
LANCECASPER Posted January 2 Report Posted January 2 6 hours ago, N911TP said: Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. Good for them, that’s an excellent problem to have. Wondering if it’s worth the wait or if I should go elsewhere. Local A&P on my airfield can do it for $1500 per wing. Pro: 10 year warranty. Done right the first time. Con: 2 day trip to MN each way plus airlines and hotels. $7500 per wing. 2 year waitlist. The fact that your A & P thinks it will take him 15 hours (@$100/hr) on each wing to do it right tells you everything you need to know. It's a much bigger job than that. He doesn't know what he doesn't know. It's isn't unusual for a small patch to cost $1500 by someone who knows what they are doing. I wouldn't want this guy learning on my airplane. If it was easy every A & P and every MSC would be doing it. 3
ArtVandelay Posted January 2 Report Posted January 2 The fact that your A & P thinks it will take him 15 hours (@$100/hr) on each wing to do it right tells you everything you need to know. It's a much bigger job than that. It's isn't unusual for a small patch to cost $1500 by someone who knows what they are doing.It’s the stripping part that takes most of the time, the AP will probably just reseal it if the original sealant is good condition. Just like repainting a house.It’s difficult to just patch a small area unless it’s a inspection plate that’s leaking, which in my experience is usually where it leaks. Either screws or the plate itself. If you have to wait 2 years anyway, I would have the AP do reseal and if see if it works and plan on a complete job later. 2
Steve Dawson Posted Friday at 12:38 PM Report Posted Friday at 12:38 PM I've heard nothing but good things about Paul and they must be true because he's always booked up for at least a year. When I bought my Bravo it had been abused and leaked profusely.(The tanks wouldn't hold more than 1/2 tank) Paul couldn't do it for at least a year so I went with Edison in Florida (WetWingologist-East) since he was available in a couple months and I couldn't wait. The funny thing was that Paul phoned me with a cancelation just after I picked up my plane. Don't be surprised if it costs a little more also. I had the fuel drains and the rivets replaced at the lift points at the spar because they had worked loose. I believe these are items that can't be seen until the tank is opened up. I forgot what the costs were but I was happy that he looked after any future tank issues
Bartman Posted Friday at 12:55 PM Report Posted Friday at 12:55 PM I agree with @ArtVandelay and would patch what is necessary for now, but go ahead and schedule at a one of the specialty shops. Edison did mine about 15 years ago and as @Steve Dawson stated above we also replaced rivets and nut holders as required so it was a little more than quoted. I tried leak repairs with limited success. Mine only leaked when filled above about 12 gallons so I only filled above that immediately before a flight if necessary, and always landing in a range where it would not leak on the ground. I did that for about 6 months while waiting for my reseal, and you might try a similar strategy. No leaks since full reseal both tanks, and I’m thinking that was around 2010.
Schllc Posted Friday at 02:43 PM Report Posted Friday at 02:43 PM Edison at KFXE was an absolute pleasure. He told me he needed the plane for four weeks. I visited several times during the work. He is very thorough, takes pictures, communicates well, and finished on time. There were no “extras”, and it is probably one of the most pleasant experiences I have had in aviation. highly recommend going to Edison at wet Wingologist. 1
PT20J Posted Friday at 03:47 PM Report Posted Friday at 03:47 PM Has anyone had experience with Houston Tank Specialists? https://htsllc.net
Fritz1 Posted Friday at 05:05 PM Report Posted Friday at 05:05 PM My tanks were sealed by Weep no more 8 years ago, no leaks, I personally know several people who had wet wingologist in FL reseal their tanks with excellent results, probably best to book either one and keep patching until then. Paul Beck does one plane a week working by himself with one helper, he has a recirculation pump system for the stripper, the sealant is applied by hand in two or three layers which brushes, real art and very hard work, 2 years sounds like a lot, there are always planes dropping out, then Paul calls around to see who might be ready to go
Planejim Posted Friday at 08:16 PM Report Posted Friday at 08:16 PM I just had mine resealed at Wet Wingologists at FXE. Eddie specializes in Mooneys and I'm very pleased with the work, although it was expensive. I have a 1983 Mooney M20K Rocket based at DVT and did the trip over three days, visiting friends and family along the way. Jim
Ragsf15e Posted Friday at 10:03 PM Report Posted Friday at 10:03 PM 14 hours ago, N911TP said: Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. Good for them, that’s an excellent problem to have. Wondering if it’s worth the wait or if I should go elsewhere. Local A&P on my airfield can do it for $1500 per wing. Pro: 10 year warranty. Done right the first time. Con: 2 day trip to MN each way plus airlines and hotels. $7500 per wing. 2 year waitlist. How bad do they look? Where’s it leaking? Where are you based? Maybe a patch can hold you over? 2
Justin Schmidt Posted Saturday at 04:27 AM Report Posted Saturday at 04:27 AM Houston tank specialist are also good. They did mine in 2019 (prev owner), looks great, no issues. 1 1
1980Mooney Posted Saturday at 07:59 AM Report Posted Saturday at 07:59 AM 22 hours ago, N911TP said: Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. Good for them, that’s an excellent problem to have. Wondering if it’s worth the wait or if I should go elsewhere. Local A&P on my airfield can do it for $1500 per wing. Pro: 10 year warranty. Done right the first time. Con: 2 day trip to MN each way plus airlines and hotels. $7500 per wing. 2 year waitlist. Do you currently have a leak? You don't mention the current status of your tanks or urgency. A severe leak will render your plane unairworthy. Has your plane previously been fully stripped and sealed or had tank repairs?
laytonl Posted Saturday at 04:48 PM Report Posted Saturday at 04:48 PM I’ve used both Weep No More and Edison at FXE (two different Mooneys). Both were excellent. Lee 1
Stubby Posted 16 hours ago Report Posted 16 hours ago I used Weep No More and was pleased with the experience and results so far. One thing that impressed me is that Paul took my info down and said he'd call me if he had a last minute cancellation or something of the sort. To my surprise, he called me out of the blue, long before my quoted time frame, and let me know he could squeeze me in if I could get out there in a couple of days. I jumped at the opportunity and I'm glad I did. 2
StevenL757 Posted 16 hours ago Report Posted 16 hours ago On 1/2/2026 at 2:55 AM, N911TP said: Does anyone have any experience with the famous Mooney wing tank resealing company WeepNoMore out of Minnesota? Called to make an appointment and they’re booked 2 years out. Good for them, that’s an excellent problem to have. Wondering if it’s worth the wait or if I should go elsewhere. Local A&P on my airfield can do it for $1500 per wing. Pro: 10 year warranty. Done right the first time. Con: 2 day trip to MN each way plus airlines and hotels. $7500 per wing. 2 year waitlist. Caveat Emptor when it comes to the less-expensive job. Re-work is always more expensive and time-consuming in the end. Paul in MN has the waiting list for a reason. Don’t waste your time with anyone else. He’s done work for me twice. Worth every penny and then some, If I were you, get on the list and check with him frequently in case there’s a cancellation and be ready to move if he can accommodate you earlier. 2
MikeOH Posted 14 hours ago Report Posted 14 hours ago @N911TP You didn't describe the seriousness of your tanks issues. Are they weeping, seeping, or leaking? Both tanks, or just one? While an often heretical view around here, the option of patching vs. an expensive total reseal should be considered. Sure, it might be an 'interim' solution but that's not necessarily such a bad thing. I've had my plane for over 8 years and have had the right tank patched twice. Oddly, the left one has never had any issue. All in, I've spent under $1K having those two patches done. Needless to say, I've been pretty happy with my 'interim' solution
