good2eat Posted March 15 Report Posted March 15 A3B6D has been out for 2 1/2 years - long story, fretted case, corrosion throughout, etc, etc, etc. I’m now being told the German manufacturer of bearings stopped making them and none can be found. New manufacturer in FAA approval process. I have searched for information on this and find nothing. Anyone have any info or is it a line of BS I’m getting?
hammdo Posted March 15 Report Posted March 15 Is the crank ground down? have you tried Air Power with the part #s? https://www.airpowerinc.com/ -Don
cliffy Posted March 17 Report Posted March 17 Need more info as to what you are looking for Just bearings for the crank and rods? Engine model complete and S/N Has the crank been ground to undersize and what size?
good2eat Posted March 21 Author Report Posted March 21 IO360-a3b6d roller tappets Case had about 500 hours, serviced through Divco. Crank and rod bearings. Crank needed no work Don’t have the case s/n available. Builder says “It is the latest bearing design” Primary reason for the post it to see if the story in my original post is true or a line of BS.
Fritz1 Posted March 21 Report Posted March 21 Get part numbers out of Lycoming parts catalog, see if you can order through Spruce, call two more Lycoming dealers like air power and Triad, the you know for sure what is going on
N201MKTurbo Posted March 21 Report Posted March 21 Lycoming bearings are made by King Bearing. Their US headquarters are in New Jersey. The bearings are manufactured in Israel and Serbia. They make bearings for both Lycoming and Superior. https://www.kingbearings.com/products/aviation/ 1
