PT20J Posted February 17 Report Posted February 17 6 minutes ago, Fly Boomer said: Instead of the adjustable tension coupler, I have been wanting to try one of these: https://locknlube.com/products/locknlube-grease-coupler?variant=32586284204116 Any experience with these lock and release types? It works but it's too long to get onto all the zerks on my plane. 1 Quote
N201MKTurbo Posted February 17 Report Posted February 17 32 minutes ago, Fly Boomer said: Instead of the adjustable tension coupler, I have been wanting to try one of these: https://locknlube.com/products/locknlube-grease-coupler?variant=32586284204116 Any experience with these lock and release types? I use one on my grease gun. I really like it. There are a couple of zerks in the nose wheel well you cannot use it on, but I bought their accessory kit and the adapters make it easy to do them. The kit is very high quality. 2 Quote
EricJ Posted February 18 Report Posted February 18 9 hours ago, Fly Boomer said: Instead of the adjustable tension coupler, I have been wanting to try one of these: https://locknlube.com/products/locknlube-grease-coupler?variant=32586284204116 Any experience with these lock and release types? I use one. They're very handy in many cases. It makes a lot of the zerks much easier to grease. 1 Quote
Hank Posted February 18 Report Posted February 18 I always find and clean all zerks on one gear leg before greasing any of them, then I start at the top and grease my way down--my arm stays cleaner by not rubbing across already-greased zerks. The nose gear has 8 fittings, each main leg has 11. Unless I have it backwards . . . But it's definitely 8 and 11. Quote
ProtoFly Posted Tuesday at 02:14 PM Author Report Posted Tuesday at 02:14 PM Update on the topic of the 'Dukes grease'. I mixed Aeroshell 64 (Aeroshell 7 with 5% Moly) with another 5% of moly. Really, REALLY dark and slippery stuff. Removed the actuator, and when I opened up the gear area, it had a much lighter color, but still 'fresh-ish' grease in there. Cleaned it all out very thoroughly, checked backlash and wear (all good), and then packed with the new mixture. SB completed. Filled up a small grease gun with the new mix, ready for the next year. I really was surprised at how small the gears really are. I expected something a bit more beefy. 2 Quote
MikeOH Posted Tuesday at 03:46 PM Report Posted Tuesday at 03:46 PM 1 hour ago, ProtoFly said: Update on the topic of the 'Dukes grease'. I mixed Aeroshell 64 (Aeroshell 7 with 5% Moly) with another 5% of moly. Really, REALLY dark and slippery stuff. Removed the actuator, and when I opened up the gear area, it had a much lighter color, but still 'fresh-ish' grease in there. Cleaned it all out very thoroughly, checked backlash and wear (all good), and then packed with the new mixture. SB completed. Filled up a small grease gun with the new mix, ready for the next year. I really was surprised at how small the gears really are. I expected something a bit more beefy. Yeah, they are shockingly tiny, IMHO. Quote
201Steve Posted Tuesday at 05:13 PM Report Posted Tuesday at 05:13 PM How did you determine the 5%? Little sprinkle with your TLAR gauge? 2 Quote
ProtoFly Posted Tuesday at 11:24 PM Author Report Posted Tuesday at 11:24 PM 6 hours ago, 201Steve said: How did you determine the 5%? Little sprinkle with your TLAR gauge? This seemed like the most difficult part. Estimating 5% by volume. So, a little on a tongue depressor stick. Since the Aeroshell 64 already has 5%, it seemed 'safe'.... 1 Quote
201Steve Posted yesterday at 12:44 AM Report Posted yesterday at 12:44 AM Yeah that’s what I did too. Quote
