That is a very good price for a sidewinder.
@AJ88V it’s a great unit, but I have the same issue: steep pitch up to my hangar and sliding door rails that were installed on the slab rather than recessed.  I will probably sell mine here sometime in the not too distant future.
-dan
16 minutes ago, AJ88V said:
@Rizvon - Have you tried a different battery?  Maybe that's all it needs to work for you.
Aviation Consumer says this unit was designed for moving 4-5,000 lb aircraft.
https://www.aviationconsumer.com/accessories/electric-tow-bars-hand-tool-powered/
Yes, I borrowed a battery from my neighbor with an E. All I’m able to do is scuff the nose wheel tire with the friction drive. Even with hangar threshold ramps, it struggles.
i just ordered a 40 EZ gas tug
this was high on my list, as my new hangar has almost no slope and no rails to contend with.  The hangar at my old place was a nightmare.
Sure you'll be able to sell it pretty quickly.  Sounds like your gas tug will fill the bill.  Good luck!
The make portable ramps for the rails.
https://www.sportys.com/hangar-ramps-set-pack-of-3.html?utm_source=google&utm_medium=cpc&utm_campaign=&creative={AdId}&device=c&matchtype=&gad_source=1&gclid=Cj0KCQjwr9m3BhDHARIsANut04ZbFQmxkUdhn4pJyyTh65tR-5Lo5sgkCMbEGPGEz6uNMK_n5raie_8aAhyVEALw_wcB
I have a lip from the asphalt taxiway to concrete floor.  I need a running start.  One day I will buy a set of these ramps.
I MacGyver'd some with  some baseboard pieces and scrap lumber fastened to a heavy rubber welcome mat. Better, but still not great.
It takes a ton of downforce on the handle to push the plane up a slope and over a lip without texturing the front tire.
-dan
