Glen Davis Posted April 26, 2024 Report Posted April 26, 2024 Does anyone have a 24/28 V power supply used to power the aircraft via the aux. power port so the avionics can be run without wearing down the battery while in the hangar that they would be willing to sell?
Fly Boomer Posted April 26, 2024 Report Posted April 26, 2024 1 hour ago, Glen Davis said: Does anyone have a 24/28 V power supply used to power the aircraft via the aux. power port so the avionics can be run without wearing down the battery while in the hangar that they would be willing to sell? Amazon. On the advice of a Concorde engineer, I set it to 28.2 volts. https://www.amazon.com/Regulated-Variable-Adjustable-Accessories-Inverter/dp/B0924K3VQ5
PT20J Posted April 26, 2024 Report Posted April 26, 2024 How much current do you need? My Batteryminder puts out about 5A@ 28V and runs my glass panel with minimum battery discharge.
Fritz1 Posted April 26, 2024 Report Posted April 26, 2024 same here I run my avionics on a Batteryminder, avionics may draw more than 5A, battery gets depleted a little, Batteryminder charges everything back up in a few hours
Red Leader Posted April 26, 2024 Report Posted April 26, 2024 Here is one in Pensacola, a complete kit; SCHAUER JAC2024H 24 volt Battery Charger Air Plane - aviation - by owner - airplane aviation parts - craigslist
