4 hours ago, Yetti said:
I am not saying that MMO will help you make a stuck valve get to annual, but if you think about it the engine design and MMO are of the same vintage.
MMO dates back to 1923 as a carburetor cleaner/flush.   Word is that radial engine maintenance outfits in WWII got it by the barrel, and used it up regularly.   It's been a regular component in aviation maintenance for nearly 100 years.   Not even remotely a new or untested thing.  ;)
How would one know…
The oil ring is a bit gummy?
Then…
How would one know…
The oil ring has been cleaned?
Sounds like…
Oil may be showing up in the lower spark plug?
A sign that the oil ring isn’t doing its job…
could be a cylinder surface quality issue as well…
If sending a camera down the cylinder is possible…
be on the lookout for polished surfaces where they used to be cross hatchings.
+1 for selecting a solvent mix that is good at dissolving carbon…
PP questions only, not a mechanic…
  • 1 year later...
Mikes recipe calls for Xylene which is no longer available in California, anybody know of a good replacement?  Googling a replacement I get Polychem 36 but can’t seem to find a source, haven’t called the manufacturer of Polychem yet.  Might just use MMO.
Goof off is mostly xylene.
I know an IA who tells me he has successfully used MMO to flush stuck piston rings. MMO contains TCP (lead scavenger), o-Dichlorobenzene (dissolves carbon), p-Dichlorobenzene (solvent) in mineral spirits. Plus the wintergreen oil makes it smell good ;)
https://cdn.shopify.com/s/files/1/0055/5922/2385/files/MM12R_50094_MM13R_50095_MM13RC_Marvel_Mystery_Oil_SDS_US_031424_FINAL.pdf?v=1733406643
Thanks, it will be the easiest way to go as well!
I always thought the mint odor of MMO was a gimmick. But, it turns out that methyl salicylate (aka oil of wintergreen) has a known beneficial effect on rubber seals.
I previously had a Sundowner to teach my kids to fly. It used the same style rubber donuts as the Mooney. Beech wanted $5000 for a full set. Before sourcing them from South Africa for $800 for the set I tried wintergreen oil. It definitely helped the old donuts. They regained elasticity and swelled up to almost new size. I just replaced the donuts on my J and I’m tempted to give them an occasional coating of wintergreen oil. It works.
