1963 C model.  I am replacing the nose wheel inner tube.  I have looked in both the Parts manual and the maintenance manual and cannot find the proper torque for the through bolts and nuts that hold the two halves of the wheel together.  Anybody have an idea where to look?  I have the Cleveland wheel torque chart which I thought the wheel was but I cannot find the actual wheel assembly model # to compare to the Cleveland torque chart.
Any advice would be appreciated.  Thanks.
Okay.  With a little digging I think I found the wheel assembly.  It is a Cleveland 40-24 according to the Cleveland application guide.  Torque is 90 in-lb dry according to the Cleveland manual.
17 minutes ago, N201MKTurbo said:
I was playing my daily crossword puzzle and it occurred to me if you rearrange the letters in Mooney C you get economy.
FAR too much time on your hands, Rich….
I think Cleveland is typically 90in-lb for 1/4 fasteners and 150in-lb for 5/16.
90in-lb is correct per the the Parker manual.
I guess I haven't looked, and having a senior moment I can't remember at the moment, but are the nuts that hold the hub halves together elastic stop nuts or just nuts?
They are stop nuts. I hate to be a bad A&P, but I just tighten them good with a 1/4 inch ratchet.
10 minutes ago, outermarker said:
So, these torque values are for nuts only, not elastic stop nuts, correct?
It depends on the engineers intent was when setting the torque. Was it clamping force, or nut stress to keep the nut from coming loose.
I suspect it is neither, and the engineer was being lazy and just deferred to the standard value for the bolt.
I believe to be technically correct we are supposed to measure the drag torque (torque required to turn the nut prior to it making contact with the surface) then add that torque to the torque.
For something like this that would be beyond silly I think.
https://www.aopa.org/news-and-media/all-news/2000/september/pilot/airframe-and-powerplant-(9)
Look under free running or friction drag torque
I spoke with a representative from Kaman (Cleveland) who called me a few days ago to discuss the nut and the part number. When I mentioned the torque spec for the nut, he said it was for the steel, self-locking nut. However, when I mentioned the part number was superseded to a common elastic stop nut, he didn't know the nut type had changed. The price range is from over $12 to $0.50 each depending on where you buy.
Aircraft Wheel & Brake Engineering | Kaman Corporation
AWBPC0001-(40-97A).pdf
AWBCMM0001.pdf (parker.com)
Cleveland 094-10400 Nut/ MS21044-N5 | Aircraft Spruce
MS21044N5 NUT, ELASTIC STOP | Aircraft Spruce
Military Standard MS21044N5 Steel Nut, Self-Locking, Hexagon at SkyGeek.com
All metal self locking nuts are spec’d for high temp applications, as brakes can make wheels hot that may be why.
Several Cirrus have overheated brakes so badly from just taxing that there have been fires, so it doesn’t take as much as you might think to get aircraft brakes hot.
https://www.avweb.com/leadnews/cirrus-to-issue-sb-on-brake-overheating-fires/
If they had steerable nose wheels I bet they wouldn’t have burned.
