William Munney Posted February 20, 2024 Report Posted February 20, 2024 (edited) Gents: Can we use something like the True Blue or Earth X or other Lithium Ion Batteries in the Ovatrion? Anyone with any experience with them? Other than that nasty thermal runaway issue it seems like a good idea and saves weight too. They are pretty far back there though so maybe its not good for CG. Edited February 20, 2024 by William Munney Quote
GeeBee Posted February 21, 2024 Report Posted February 21, 2024 You might save weight.....until you have to add Charlie weights to maintain CG. Quote
StevenL757 Posted February 21, 2024 Report Posted February 21, 2024 @William Munney I’m not sure about the EarthX product, but the only airframe that is approved to use the TB17 from True Blue Power is the A36 Bonanza. Even if it becomes available for the Ovation, you likely won’t want to pay the price for one of them…let alone two. They’re easily north of $4,500 apiece. Edit…just had a look again (been over a year since I saw them around $4,500), and Spruce has them - albeit out of stock - for the bargain price of $6,779. Each. Quote
exM20K Posted February 21, 2024 Report Posted February 21, 2024 40 minutes ago, GeeBee said: You might save weight.....until you have to add Charlie weights to maintain CG. Or just add A/C. Quote
philiplane Posted February 21, 2024 Report Posted February 21, 2024 I will be the last guy to sign up for these batteries. It's a solution in search of a problem. 2 Quote
William Munney Posted February 21, 2024 Author Report Posted February 21, 2024 Well. That settles that. I had no idea they were so expensive. And we haven’t even got to CG or safety yet. I’ll pedal a portable generator before I spend $6k for a battery. Thanks all. Anyone know where the best prices are for the Concorde batteries?…….’96 Ovation. Quote
Hank Posted February 21, 2024 Report Posted February 21, 2024 5 hours ago, William Munney said: Well. That settles that. I had no idea they were so expensive. And we haven’t even got to CG or safety yet. I’ll pedal a portable generator before I spend $6k for a battery. Thanks all. Anyone know where the best prices are for the Concorde batteries?…….’96 Ovation. Lately, the problem has been availability rather than pricing. Good luck! Quote
FJC Posted February 24, 2024 Report Posted February 24, 2024 Ovation Batteries: around 850 each. Plan ahead...they are hard to find! Quote
A64Pilot Posted February 26, 2024 Report Posted February 26, 2024 On 2/20/2024 at 7:57 PM, GeeBee said: You might save weight.....until you have to add Charlie weights to maintain CG. Due to the arm difference you would save some weight, but I can’t imagine the weight would be enough to justify the price. Anyone know what the “Instructions for Continued Airworthiness” is for these things? do you do capacity checks or similar yearly? Ref yearly cap checks, most of us don’t have the $$$ to invest in a “real” capacity tester so we Rube Goldberg something like light bulbs as a load etc. and keep track of time, but as voltage drops the amp draw increases so it’s not real accurate but close enough. A couple of months ago I put LifePo4 batteries in my Golf Cart and due to some extent the relatively flat voltage discharge it went dead on me and I had to tow it home. So I installed a Columb counter battery monitor a few days ago which tracks amp hour usage very accurately, thing costs about $30 and is dead nuts accurate. Well I had an epiphany, this thing would be perfect for doing a cap check on an aircraft battery, simply connect it to your battery apply a load and when you hit terminating voltage it will tell you exactly in amp hours what your batteries capacity is. Quote
William Munney Posted February 28, 2024 Author Report Posted February 28, 2024 On 2/23/2024 at 7:15 PM, FJC said: Ovation Batteries: around 850 each. Plan ahead...they are hard to find! Aircraft Spruce has them. And now I do too! Yep. Expensive! Quote
daytonabch04 Posted February 28, 2024 Report Posted February 28, 2024 Last weekend, I was AOG due to dead batteries. I paid right around 870 and then shipping/tax came out to about 1k total. Luckily, I found a place that had them in stock, but when your plane won't start at the fuel pump your options are rather limited... 1 Quote
