DXB Posted May 21, 2023 Report Posted May 21, 2023 I have the 27.4 gal/ side Griggs bladders in my C. The fuel drain valve on one side just started leaking pretty briskly. I believe the part is distinct from the valves on the factory wet wing. I don’t think it’s sediment holding the valve open - tried to clear it multiple times without success. I suspect the o-ring is toast. Anyone have the right part number to replace the o-ring or the whole valve as necessary? Anything else I might be missing here?
M20F Posted May 21, 2023 Report Posted May 21, 2023 All I will say is use proper torque fitting putting the new one in or you will twist it off, not that I would have any experience with that…. 1
BDPetersen Posted May 21, 2023 Report Posted May 21, 2023 I had an errant clamp that nicked the nipple on the bladder, causing a leak. Had to send the tank in for repair. Hope yours is simpler. 1
A64Pilot Posted May 21, 2023 Report Posted May 21, 2023 2 hours ago, M20F said: All I will say is use proper torque fitting putting the new one in or you will twist it off, not that I would have any experience with that…. Need more information, are you saying there is a special tool, or are you saying don’t overtighten?
M20F Posted May 22, 2023 Report Posted May 22, 2023 18 hours ago, A64Pilot said: Need more information, are you saying there is a special tool, or are you saying don’t overtighten? Don’t over tighten the brass is a little fragile.
A64Pilot Posted May 22, 2023 Report Posted May 22, 2023 11 hours ago, M20F said: Don’t over tighten the brass is a little fragile. Got it, thanks that’s what I thought 1
DXB Posted May 24, 2023 Author Report Posted May 24, 2023 Fixed! thank goodness it was the drain valve and not the nipple of the bladder or some other source. Here’s the part for future reference for bladder owners: F-391-18
Yetti Posted May 25, 2023 Report Posted May 25, 2023 Think the part number is written on the face of those. This is not a tractor tight application of torque. Snug it and bit.
DXB Posted May 26, 2023 Author Report Posted May 26, 2023 10 hours ago, Yetti said: Think the part number is written on the face of those. I think so - it was a bit tough to read when 100LL was dripping in my eyeball though
