Replacing old, stiff, worn-out brake hoses on our M20K.  Each one was strapped to the landing gear structure with two of these thin metal straps, wound several times around the tube and hose, with anti-chafe tape underneath.  They are held in place with just a belt-buckle type mechanism.  What are these called? Internet search did not identify them.
They seem like a poor choice with sharp metal edges, and these are clearly worn out.  Each one got replaced with a pair of padded Grip-Lock zip ties.  But I'm curious what they're called and whether that's appropriate.
Wraplock?  From the J model IPC…
I guess it is Wraplock.  Shown in the IPC, sort of.  Thanks, that wasn't too obvious.
