I got all new engine hoses, getting them off took 2 full days! getting them on forget about it!
I have removed all cowlings all scat hoses even the exhaust and still don't have enough room for my meathooks. I'm think i should have removed the engine it would have been easier!
  • Sad 1
The gauge lines are bit of a PITA to connect to the engine as I recall, but the line running from the governor to he prop control fitting is the most time consuming to route and secure. Still, two days seems like an awful lot. Admittedly, it’s much easier to contend with some of the hoses with the engine on a hoist.
If you loosen the lower motor mount bolts so the engine can pivot, grab the engine with a hoist. Remove the top motor mount bolts (the 1/4 inch ones), you can pivot the engine down a bit. Just be mindful of the control cables.
Expand
There is a pair of hoses on my C that go from the accessory case down to the cowl mounted oil cooler.  They are secured to the firewall with a pair of “butterflied” adel clamps.  Getting those adel clamps loose is difficult.  Getting them back on without tilting the engine mount or pulling the engine entirely is well nigh impossible.  When I installed mine during the engine change I had bad dreams about those oil lines being too short or too long, and in the end I would have liked them to be .25 inch shorter, but it worked out. Thankfully I used the expensive Teflon hose that has a longer service life than standard Aeroquip hose because I dread ever having to do anything with them again….
Expand
I still vividly recall changing those oil cooler hoses in my E model, even though it was close to 30 years ago.   It was awful.
Expand
Sounds like you’re spending too much time on the first letters in your signature and not enough on the last letters.  It’s a Mooney, they have parts that are a challenge to work on, but not impossible.
Expand
true, true there once was a time when all I did was work on piston aircraft but now at age 60 working on the ramp in the sun in Georgia(it was 92 Degrees the other day) can be challenging add in the part where the plane is a mooney and bam instant can of whoopass! I will overcome and one day get this bird in a hangar but until then I shall remain
humbled by my Mooney!
Adel clamps are a whole lot easier to deal with if you first clamp them shut with needle nose vise grips with an awl or phillips screwdriver  in them to hold alignment, wrap safety wire around the base and tighten, with them on the hose of course, then line them up and put the screw through, for double clamps attached to each other it really makes life easier.
Expand
When my AP/IA taught me this trick it was life changing.
Expand
I think I was working on aircraft for a year or two until I saw it done, it’s like the Ajax on a screwdriver trick or using vise grips to remove panel screws or cutting the head on a panel screw making it a slotted screw. Things you pick up after school
Expand
I tell my apprentices to develop some finger strength for holding Adel clamps. No need to destroy them while installing them.  You could also use the Cirrus style of Adel clamp with the locking feature, they hold themselves together making assembly of multiple clamps simpler.
The tool above is great which I used to do the same PITA job you just described. Also as a jet mechanic, we use a good old pair of reverse safety wire pliers on the Adel clamp. Then put it in reverse to remove the wire. Use the awl to align it all up before hand! hope that helps....:D
The Clamp Keeper is good for tight spaces.  It’s works with both #8 and #10 threaded fasteners.  Pricey, though… a 10-spot and change per, but sold only in lots of 5 by Monroe Aerospace.  I’m passing my extras out to my IA and fellow knuckle-draggers.
Expand
Yep!! :)
  • 2 weeks later...
