Hi All,
I recently removed the front seats on my Mooney M20J. The seats had been stickling a little when I tried to slide them. This is a new to me Mooney and it appears the rails had not been cleaned in years. My question is: Should I lubricate the tracks after I clean the rails? If so, what type of lubricant is recommended?
Usually cleaning the rails and making sure the seat rollers are in good shape is enough. Mooneys sit on the ground about 5 deg nose up. If you get things too slick, you’ll roll down hill pretty fast when you unlatch the seat :) if you really want lube the rails, rubbing them with a block of paraffin wax works well.
Skip
1 hour ago, awesb said:
Hi All,
After cleaning the rollers you need to lubricate the bearing. I clean the roller with alcohol. I use LPS2 to lube the bearing.
Edited by 1980Mooney
check the Deldrin rollers on the seats if there not rolling well after cleaning up the rails. they do wear out but not expensive to replace and new ones should slide easily.
If your seat rails are funky, the holes for the seat lock pins might be funky, too.  Clean them out with a toothpick and vacuum up the little plugs of crud you dig out.  And now you’ll feel better knowing your seat pins are secure in the seat rail.
Expect wheels to not be working as expected…
Delrin is the new material used for wheels…
The old wheels were brittle and have a tendency to break…
PP parroting the knowledgeable MSers above…
While cleaning and lubricating… vac out the holes for the seat pins…
I have old wheels, pretty sure they are phenolic
On 2/6/2022 at 7:36 PM, awesb said:
Hi All,
Yes, silicone lubricant, goof off pro makes quick work of old oily residue.
Thanks A64!
Phenolic resin… a nice thermoset polymer often filled with brown paper….
They are used for low cost, moldable, machinable parts…
They last about 30 years…
often seen on old sail boats for blocks used for mechanical advantage… with good salt water resistance…
My 65C shed some of its seat wheels, and was running on the axles…
Took me a while to figure that out…
Last comment, you really, really don’t want wheels that are broken or don’t slide etc., it wears the tracks, and I believe even if you can get new ones, they are a real pain to replace as in ($$$).
I need to replace my wheels if Lasar has them
Edited by A64Pilot
A 1/4 drill bit turned with your hand will get the dirt out of the holes..  You can buy Derlin rod the right size.  Getting the hole in the center was done with a jig and a mini horizontal mill
Or a small lathe would work, even a wood lathe as long as you have a chuck to hold the delrin.
That would if you were turning it down from larger size.  Getting the center on a lathe is hard work.   So if the rod is already to size you need to be accurate on you hole.    Ya I started with the lathe first.
