bmcconnaha Posted June 18, 2021 Report Posted June 18, 2021 Just received my plane back for getting an audio panel installed. The gear down light doesn’t work any longer. Both when I press the test and when the gear is down and locked. Suspect the bulb. Anyone know what bulbs are in a 1990 28V J model? And how to get to them? Quote
PT20J Posted June 18, 2021 Report Posted June 18, 2021 The filaments can break from the shock when the annunciator panel is removed and replaced. It was my gear down light also; likely because that one is on the most and the heat weakens the filament over time. Getting to the bulbs can easy or a PITA depending on if someone before you overtightened the screws. There are 4 phillips screws on the front panel of the annunciator. Remove the screws and the panel comes off and you can get to the bulbs. They are bi-pin types and just pull out. I just replaced the burned out one with one that was in an unused position. The front panel screws thread into standoffs that are swaged into a PCB. If overtightened, the standoffs come loose and just spin with the screws and the screws won’t loosen. If that happens, you will have to take the panel out and take it apart and fix it. Skip 1 Quote
bmcconnaha Posted June 18, 2021 Author Report Posted June 18, 2021 21 minutes ago, PT20J said: The filaments can break from the shock when the annunciator panel is removed and replaced. It was my gear down light also; likely because that one is on the most and the heat weakens the filament over time. Getting to the bulbs can easy or a PITA depending on if someone before you overtightened the screws. There are 4 phillips screws on the front panel of the annunciator. Remove the screws and the panel comes off and you can get to the bulbs. They are bi-pin types and just pull out. I just replaced the burned out one with one that was in an unused position. The front panel screws thread into standoffs that are swaged into a PCB. If overtightened, the standoffs come loose and just spin with the screws and the screws won’t loosen. If that happens, you will have to take the panel out and take it apart and fix it. Skip Thanks skip. Mine only has two screw, but I will pull them off and take a look. Quote
A64Pilot Posted June 18, 2021 Report Posted June 18, 2021 I think I would replace all of the bulbs that were used, assuming you can get them prior to removal Quote
PT20J Posted June 18, 2021 Report Posted June 18, 2021 Found a couple of photos. 1994 M20J. IAI is still around and should be able to tell you what the bulb part number is if you need to buy one. Skip Quote
StevenL757 Posted June 18, 2021 Report Posted June 18, 2021 I have several of these bulbs available new from an earlier project when I replaced mine. @bmcconnaha, let me know where you’d like them shipped and if you cover shipping, I can send you a few. Steve Quote
bmcconnaha Posted June 18, 2021 Author Report Posted June 18, 2021 3 hours ago, StevenL757 said: I have several of these bulbs available new from an earlier project when I replaced mine. @bmcconnaha, let me know where you’d like them shipped and if you cover shipping, I can send you a few. Steve appreciate that. i got it working this morning. used my ram air bulb, since i no longer have ram air. so for now i am good. the bulb ( for future reference) is a two prong AML7327. thanks to everyone who replied. fix was easy 1 Quote
LANCECASPER Posted June 22, 2021 Report Posted June 22, 2021 On 6/18/2021 at 4:20 PM, bmcconnaha said: appreciate that. i got it working this morning. used my ram air bulb, since i no longer have ram air. so for now i am good. the bulb ( for future reference) is a two prong AML7327. thanks to everyone who replied. fix was easy https://www.aircraftspruce.com/catalog/elpages/aml11-12419.php Quote
