DAVIDWH Posted May 10, 2021 Report Posted May 10, 2021 A little lagniappe I was not expecting. Old avionics removed and replaced with new. The unexpected lagniappe was 47.1 pounds of increase in useful load. The table was piled high with 95 era avionics and was disposed of ( Priced as a group) pretty rapidly on e-bay. Not sure of the weight, but expect the two vacuum pumps were possibly a major contributing factor. 1 Quote
StevenL757 Posted May 10, 2021 Report Posted May 10, 2021 4 minutes ago, DAVIDWH said: A little lagniappe I was not expecting. Old avionics removed and replaced with new. The unexpected lagniappe was 47.1 pounds of increase in useful load. The table was piled high with 95 era avionics and was disposed of ( Priced as a group) pretty rapidly on e-bay. Not sure of the weight, but expect the two vacuum pumps were possibly a major contributing factor. Your detailed work order and revised W&B should indicate the before and after weights. Pictures. Or it didn't happen. :-) Quote
Will.iam Posted May 11, 2021 Report Posted May 11, 2021 11 hours ago, StevenL757 said: Your detailed work order and revised W&B should indicate the before and after weights. Pictures. Or it didn't happen. :-) Where is your faith brother? :) Quote
carusoam Posted May 11, 2021 Report Posted May 11, 2021 I think Lagniappe is one of my favorite MS words of the day... Especially when it comes to improved UL! -a- Quote
