Fly Boomer Posted July 22, 2022 Report Posted July 22, 2022 9 minutes ago, M20Doc said: Well, I’d suggest installing it on the Ford it’s meant for. Got the pic off the Internet. You can find almost anything there! Quote
Fly Boomer Posted July 22, 2022 Report Posted July 22, 2022 12 minutes ago, M20Doc said: Well, I’d suggest installing it on the Ford it’s meant for. Is there somewhere on the TSIO-520-NB (permold) to hook up a pressure pot after the dry filter is installed? Quote
LANCECASPER Posted July 23, 2022 Report Posted July 23, 2022 2 hours ago, Fly Boomer said: They're all the same, aren't they? Call Continental (or Lycoming) and check with them. Better yet call the FAA. Quote
Guest Posted July 23, 2022 Report Posted July 23, 2022 11 hours ago, Fly Boomer said: Is there somewhere on the TSIO-520-NB (permold) to hook up a pressure pot after the dry filter is installed? Through any easily accessed oil gallery plug at the front of the engine. Clarence Quote
PWL Posted July 24, 2022 Report Posted July 24, 2022 By cutting a Phillips X-country oil container across the narrow side, it is possible to make a container that just slips under the oil filter of a j-model that will hold all of the residual oil in the filter. It is then possible to remove the filter (wear rubber gloves as it gets oily) and then extract the oil container. After two small oil leaks that developed at the filter seal (didn’t show up immediately after the leak test runup), I bought a Tempest oil filter torque wrench and have not had a problem since. 2 Quote
PT20J Posted July 24, 2022 Report Posted July 24, 2022 15 hours ago, PWL said: After two small oil leaks that developed at the filter seal (didn’t show up immediately after the leak test runup), I bought a Tempest oil filter torque wrench and have not had a problem since. How were you torqueing it before? Quote
Marauder Posted July 24, 2022 Report Posted July 24, 2022 How were you torqueing it before?Sent from my iPhone using Tapatalk Pro 3 Quote
