Hi folks,
has anyone with an EASA-reg vintage Mooney (A-G) upgraded their aircraft with 3-point seat belts? There is a FAA STC by Alpha Aviation But nothing else.
If you have a shoulder harness, where did you get it and what is the legal base for its installation?
The CS-SC153b only allows the replacement of existing belts, but no upgrade or new installation.
Thanks!
Edited by MV Aviation
  • 4 weeks later...
my front seat shoulder harnesses were validated by the Danish CAA a while back and you should be able to grandfather that. Drop me your email and I ll scan what I have.
  • 4 weeks later...
I did upgrade my M20F with with 3-point seat belts by Alpha  Aviation.
Mooney Service Center in Germany did all the job.
I'm very satisfied.
BR
Andrea
  • 1 month later...
I'm very satisfied.
BR
Andrea
Hi Andrea, can you elaborate a bit on the paperwork? What is the legal base for the install?
The vintage Mooneys did not feature 3-point belts from factory, so it's hard to argue that it's only a replacement. Hence, one needs an STC (which does not exist for EASA aircraft to my knowledge) or minor/major change paperwork.
Thanks for your help!
Marco
