Gee Bee Aeroproducts Posted January 26 Report Posted January 26 7 hours ago, A64Pilot said: Your right silicone is NOT oil or fuel resistant, if you put them on your car for radiator and heater hoses don’t let oil get on them and do not use Gunk to clean your engine. However flurosilicone is very fuel resistant. However I suspect that as fast as 100 LL evaporates that cheap baking etc mats would be fine, and if they deteriorate after a couple years they are still a deal. The Gami fuel I have no idea but suspect that it would be even less tolerant to that. Not true , we mfg Flurosilicone hoses for the Vw / Porsche market Molded per original I also mfg molded silicone coolant hoses for various automotive platforms. I started doing TRD division of Toyota back in 1999 Were the only mfg that can do the fabric European finish. 1
A64Pilot Posted January 26 Report Posted January 26 So what are you saying is untrue? That Silicone hoses aren’t oil resistant? If so then why do you manufacture Flurosilicone hoses?
Gee Bee Aeroproducts Posted January 26 Report Posted January 26 Flurosilicone liner is fuel and oil resistant, we also mfg fuel intake pipes , such as fender to the tank. VW and Porsche air cooled as shown non flurosilicone liner is not , Great for air , vacuum,coolant We have molds / mandrels for many assys . We’re tooling for coolant hoses for the new stark Varg I duplicated and modded the boost hoses on my Turbo S , added 20% more flow volume with new hybrid turbos with new boost ducts also . We don’t charge for tooling as we have unlimited funding for projects. My favorite is doing canopy seals for private owners of military aircraft or the sl300 Gullwing Mercedes
Gee Bee Aeroproducts Posted January 26 Report Posted January 26 Storage Tube I designed these after my paint work was completed. no more fuel nozzle damage or hose on the my deice boot . We stock ams3325 Flurosilicone, we die cut to your specifications. We can cut 1k seals per hour with our atom clicker presses. There various fuel tank and tip tank mfg that want the best material. 25.00 to 45.00 per seal .032 or .062 thickness is stock , material is 50 inches wide . sold with material certs.
