Neshi Posted May 8, 2020 Report Posted May 8, 2020 Can the G5 accept information from 2 nave sources. like a gnx375 for gps & a sl30 for nav? Quote
oldguyscanfly Posted May 8, 2020 Report Posted May 8, 2020 My G5's accept nav data from my GNX375 and my GNC 255 Quote
AH-1 Cobra Pilot Posted May 8, 2020 Report Posted May 8, 2020 No. I just had a GNX-375 installed and had to add a G5 HSI. It does not accept input from my SL-30. Quote
bradp Posted May 8, 2020 Report Posted May 8, 2020 No dual Nav sources for STC g5 unless there is a garmin autopilot and you remove your second CDI. SL-30 won’t work just because it lacks airinc out. Quote
Neshi Posted May 8, 2020 Author Report Posted May 8, 2020 Thanks all. Sent from my iPhone using Tapatalk Quote
Paul_Havelka Posted May 8, 2020 Report Posted May 8, 2020 The SL30 will work with a G5 via rs232 Quote
Ragsf15e Posted May 9, 2020 Report Posted May 9, 2020 Ok, I don’t have the documentation in front of me, but I think it will accept 2 digital inputs... so not an old VOR, but an sl30 with a 430w should work. The AP wiring could affect that though. Quote
bradp Posted May 10, 2020 Report Posted May 10, 2020 On 5/8/2020 at 9:10 PM, Paul_Havelka said: The SL30 will work with a G5 via rs232 Expand I don't think the RS232 will provide vertical flag / vertical error outputs. I could be wrong; but I looked into this when I was upgrading my Nav2 and decided to go with a GNC255 (they were essentially the same price used). Quote
