Danb Posted March 23, 2020 Report Posted March 23, 2020 I just changed oil and serviced plugs, have some sort of leak, I thought exhaust leaks were white, this is tan could it be an oil leak the above pipe hose clamp is damp
PaulM Posted March 23, 2020 Report Posted March 23, 2020 1 hour ago, Danb said: this is tan could it be an oil leak the above pipe hose clamp is damp Dan, Do you run LOP?.. It's a thermal reaction to the paint.
PaulM Posted March 23, 2020 Report Posted March 23, 2020 It doesn't seem to be leak related on my engine, but thermal effects on the exhaust pipe coating. CYL#4 correct?.. same as my picture. If you think it is a leak, then put the CO monitor near it, that should go off quickly. Check that the valve guide injectors are tight to see if that is the source of the oil.. 2
carusoam Posted March 24, 2020 Report Posted March 24, 2020 It doesn’t look like a leak with an origin escaping from a joint, or crack, or hole... If it is a leak... A CO monitor would be a good tool... Does look a lot like what PaulM has... If that is a coating... is it staying on or does it need help? Dan, Any JPI data to share? (hotter than usual EGT on that tube?) Lets ask @M20Doc... (stain on a Bravo exhaust tube question...) Best regards, -a-
Guest Posted March 24, 2020 Report Posted March 24, 2020 Only a guess, but oil leaking on the pipe as there is normally no coating on the pipes that I know of. Clarence
PaulM Posted March 24, 2020 Report Posted March 24, 2020 4 hours ago, M20Doc said: Only a guess, but oil leaking on the pipe as there is normally no coating on the pipes that I know of. I'm pretty sure that matte surface isn't pure iconel, so I'm assuming some sort of paint after it is welded. It could be that the color is a combination of the paint, some oil leaking and the heat out of the exhaust port. Both #2 and #4 cyls have had oil leaked before I noticed the orange patches. Mostly on #4, but a bit on #2.
LANCECASPER Posted March 24, 2020 Report Posted March 24, 2020 That looks like steel plus oxidation. I've never seen a coating on a Bravo exhaust system.
drstephensugiono Posted March 24, 2020 Author Report Posted March 24, 2020 I have that discoloration on the exhaust tip also. Seems to develop even with no oil on it.Sent from my iPhone using Tapatalk
drstephensugiono Posted March 24, 2020 Author Report Posted March 24, 2020 Sent from my iPhone using Tapatalk
LANCECASPER Posted March 25, 2020 Report Posted March 25, 2020 What Turbine Inlet Temperature do you lean out to?
drstephensugiono Posted March 25, 2020 Author Report Posted March 25, 2020 90% at 32/2400 @19.7gal/hr TIT around 1580Sent from my iPhone using Tapatalk
carusoam Posted March 25, 2020 Report Posted March 25, 2020 That is an interesting twist... Similar color on the exhaust tip.... That would probably be the coolest part of the exhaust system..... still hot just cooler than every part up stream... Before the turbo would be the hottest parts of the exhaust.... Inconel... is a nickel based stainless steel... so there is no ‘pure’ inconel... per-se.... It is pretty good at handling heat, and chemical environments... Anyone know any exhaust welding shop contacts? Or somebody at Lycoming? We could ask them what this is when they see it? If it is exhaust gas related... this would be more important to know about under the cowl... Might be a variation of oil getting baked in an air environment.... A small drop of oil getting dropped on the outside of the pipe... A small drop of oil getting delivered on the inside of the pipe... Looks like it could/might get cleaned off...??? To see how quickly it returns... Dan’s looks similar to something dripping and building up in the area... and possibly spreading Paul’s, is in a similar place, shares some 3D characteristics... that, might be a high temp ceramic coating that may be coming off... similar to JetHot coatings.... used on exhaust systems... Stephen’s is possibly showing the end effect of the coating not being able to stick where the pipe has sharp corners or may have been cut after the coating was applied.... These are Only observations I have made about the three pics above... They are PP thoughts only, not a mechanic... Best regards, -a- 1
LANCECASPER Posted March 25, 2020 Report Posted March 25, 2020 On 3/24/2020 at 10:32 PM, drstephensugiono said: 90% at 32/2400 @19.7gal/hr TIT around 1580 Sent from my iPhone using Tapatalk In the first Bravo I owned I used to run it at 32/2400. If I wanted to go faster i even ran it at 34/2400 with the limitation being TIT of 1750 or less. Flight Safety in my initial Bravo training told me this was an approved power setting and the POH agreed. But after sitting in on Bravo forums at MAPA and talking to other Bravo owners, the last couple Bravos I've owned I run at 29/2400. The high power settings came from the marketing department way back when trying to get the max cruise speed to 220+ knots at FL 250. They would tell you that the TIO-540 in the Piper Navajo was pushed to 350hp, so really at 270hp the Bravo engine was practically idling*. The only problem with that is that they are completely different engines, not sharing a single common part. The numbers looked great on the brochure, but those high settings printed on the visor push the engine too hard, they also take its toll on the exhaust. Bravo experts will tell you that the "Magic number" you're looking for is 53 or less (example 29 + 24 = 53) if you want to come close to getting TBO out of your engine and not get incinerated by a failure to the exhaust system. (* this incorrect theory gained more traction in 1996 when Richard Collins wrote on article in Flying after the Bravo conversion in September 1996.) Later while sitting in seminars where Lycoming representatives were present they confirmed that comparing the Bravo engine to the Navajo engine was completely ludicrous - different cylinders, crankshaft, camshaft, etc. etc. They said it should be compared to the Commander 114 or the Trinidad TB21 which were both rated at 250hp. 1
drstephensugiono Posted March 25, 2020 Author Report Posted March 25, 2020 At 29/2400 what fuel flow?Sent from my iPhone using Tapatalk
LANCECASPER Posted March 25, 2020 Report Posted March 25, 2020 3 hours ago, drstephensugiono said: At 29/2400 what fuel flow? Sent from my iPhone using Tapatalk 18.0 with 1600 TIT 1
drstephensugiono Posted March 25, 2020 Author Report Posted March 25, 2020 I’ll try itSent from my iPhone using Tapatalk
Davidv Posted March 25, 2020 Report Posted March 25, 2020 (edited) I would call Acorn welding and possibly send them a photo. I have found them extremely helpful and they know our exhaust pretty well. I have a similar color on the tip of my exhaust. On a side note, do whatever you can temp wise to preserve your turbo transition piece (the "T" part that connects to your 4&6 exhaust stacks as well as turbo). None of the fabricators seem to want to work on it anymore and it's a $5K cast piece that you must buy from Lycoming... Edited March 25, 2020 by Davidv
drstephensugiono Posted March 25, 2020 Author Report Posted March 25, 2020 I would call Acorn welding and possibly send them a photo. I have found them extremely helpful and they know our exhaust pretty well. I have a similar color on the tip of my exhaust as well. On a side note, do whatever you can temp wise to preserve your turbo transition piece (the "T" part that connects to your 4&6 exhaust stacks as well as turbo). None of the fabricators seem to want to work on it anymore and it's a $5K cast piece that you must buy from Lycoming... Sent from my iPhone using Tapatalk
carusoam Posted March 25, 2020 Report Posted March 25, 2020 Acorn Welding lists the M20R exhaust system on their site... https://www.acornwelding.com/aircraft-exhaust I sent them a request through their contact us page... linked back here... Best regards, -a-
Lami Posted April 3, 2020 Report Posted April 3, 2020 I have a 1977 M20C with 400 hrs on the engine. Its a B to start. Weather hot,cold no matter it sucks all the time. It been like that since i purchased three years ago. I have to pump it 30 times some and no fuel on the ground. Its crazy, the shop looking at it for past two years can't figure it out, and they are no joke, super competent people. I am now replacing the carb. I have a feeling that's not going to work either. Talked to a few Mooney owners ( they had same problem) and they both went to fuel injection. I really don't want to go that far. Looked at all the obvious of course, electric pump working, fuel lines all good, pressure correct, mixture working correctly, plugs are in order, Carb has been inspected and looks good. Any help would be great. Thanks
carusoam Posted April 3, 2020 Report Posted April 3, 2020 Let’s start a new thread, Lami. A title that includes the words M20C and O360... expect to cover details related to your carb... can be as simple as the accelerator pump needing some help...(mine did) Magnetos take a lot of the responsibility as well... and their support systems... Left mag and its vibrator thingy... wires and plugs usually cap things off... How many hours on the major parts? Was the carb OH’d this century? Want to get started, need a hand? PP thoughts only, not a mechanic or internet moderator... Best regards, -a-
