So my '67 F has a 500 hr recurring AD to inspect the yokes.  The AD isn't due for another 80 hrs, but my IA knows I fly about 100 hrs a year, so he checked it.  Sure enough, the tapered pin on the pilot side yoke and the set screw have been over tightened and cracked the cast aluminum yoke (I'll follow up with a pic).  Anyone have a spare yoke laying around that will fit a '67 F (part number 917010-501)?
The yoke shaft also has a depression where the set screw was over tightened and I'd replace that too if I can find one reasonably priced (not sure on the part number).  Calling @Alan Fox @SheryLoewen, @Jerry Pressley, others?
I know theres a set of yokes that arent crazy expensive that come with an Stc. They are indentical to the beech yokes. Those might be a nice option. I know one guy on here has a set of them. I cant remember the name however.
So this is a case where the AD is likely causing more harm than good.  I wonder when the last time this AD actually found a cracked shaft that it didn’t cause?  Ironically, you don’t catch that for another 5 years...
So I went back and read the AD this afternoon, which applies to the shaft and not to the yoke itself.  So technically, I didn't fail the AD, but understandably my IA was hesitant to sign off the annual with the yoke cracked.  His words, "This would probably never break, but if it did..."
@Alan Fox I'll send you a PM.
You're referring to the Cygnet yokes I believe.  When I looked into them a few years ago they required a field approval to install on a Mooney.
True. I called them about it last week.
There may be a different AD...?
The rams horns have seen some need for replacement over the years...
They are also surrounded by a tough environment... Often warm and salty.
The FAA didn’t like powder coating for a while...
Our yokes got plastic dipped... another way that hides corrosion and cracks...
It may be possible to repair the crack... but it would cost a lot less to swap out the old yoke for a different one...
And get some Fancy leather put on them...
Find the thread where Peter did his own fancy leather yokes... they came out quite nice. :)
10 hours ago, KSMooniac said:
Those didn't last long! (I got the seats and hope to go pick them up soon)
Sent from my LG-US996 using Tapatalk
I know! From listing to money in bank in less than 30 minutes...I guess I sold them too cheap...
  • 4 years later...
Can a cracked yoke be welded and re-drilled?  I know it's cast aluminum, but a good welder can do stuff like that.  Especially since the parts are still held closely together.
We certainly accept that for things like cracked engine cases (speaking from experience :().
  • 2 weeks later...
Not for $150 from a few years ago even accounting for inflation.
