Hradec Posted January 5, 2020 Report Posted January 5, 2020 I'm trying to resurrect my 64 m20e serial #311. Hasn't flown in 4 yrs. Lots of play in the nose wheel, logs show a fairly recent overhauled lasar steering horn installed. That part is ok. However it was parked outside tail into the wind with no rudder lock. The rod ends took a beating. Examining the steering horn assy, looks like most of the play was in the upper center rod end. Looked pretty cheesy, hollow rod end with a hole drilled in it. Appears that that hole double or tripples the price of that rod end. IPC 203 part number 720014, IPC 205 part number 914012-013. IPC 202 shows it, but no part number. While doing a google search, I found a part at texas salvage that looked like a better older style part, today being substituted with a lesser part with a hole drilled in it. The "better" part is also worn, but I would like to find a new part like this. This part on the ball bushing has written heim F31-14a Mooney 914030. Has flat spots machined to the sides and 2 washers brazed. Looks like it would wear better than the part number used today, the new one just flops around orcwill shortly after installation. Any thoughts opinions? Get a regular rod end an modify? Is this an original part before cost savings were implemented? Thanks Glenn Quote
carusoam Posted January 5, 2020 Report Posted January 5, 2020 The rudder doesn’t usually get locked because it is attached to the nose wheel... The nose wheel doesn’t move very much when in contact with the ground... So if you see a really narrow wear pattern there is plenty of wear in the system, allowing some motion... If it is full motion wear, that would be unusual of wearing while at the tie down area... We could ask @M20Doc what he has seen in his travels... regarding rod end bearings and wear... Best regards, -a- Quote
Hradec Posted January 6, 2020 Author Report Posted January 6, 2020 It's an old plane, lots of rod ends with wear that adds up. Couple of spots had a lot of wear causing slop in the nose wheel steering. Just trying to replace parts with the most wear. Seems that through my research a better part may have been used before that was more resistant to wear. The rod end being sold today as the replacement part is not as good as what I suspect was an earlier design. Or did someone see this as a poor design and improved on it? Quote
Guest Posted January 6, 2020 Report Posted January 6, 2020 I’ve never seen one with the brazed washers, they’ve been like the one in the LASAR picture. Clarence Quote
Andy95W Posted January 6, 2020 Report Posted January 6, 2020 My suggestion- send it back to LASAR for IRAN. They’ll do it right at a reasonable price. Quote
Hradec Posted January 6, 2020 Author Report Posted January 6, 2020 On 1/6/2020 at 12:43 AM, Andy95W said: My suggestion- send it back to LASAR for IRAN. They’ll do it right at a reasonable price. Expand It's just the rod end that got worn, very low time on the steering horn, the horn is fine Quote
Hradec Posted January 6, 2020 Author Report Posted January 6, 2020 On 1/6/2020 at 1:40 AM, pmccand said: I replaced my old style rod ends with the brazed on versions with the newfangled washerless versions several years ago. You will be adding a couple regular washers to the new unit when you put the bolt back through the holes. Funny thing is that after I spent a gazillion dollars on the overhaul, the unit had just about as much slop when I finished as it did before I tore it down. yet it takes off and lands just fine even with all the the slop. Expand So the brazed one is an actual Mooney part! Seems like you could get a lot more life out of the brazed one. The current replacement is a joke, it's a $45 rod end with a $100 hole drilled in it. No support, drilled hole shortly goes oblong. Imagine a solid rod end with machined flats with washers brazed on. Has to last a bit longer than what is offered today. What year and type of mooney did you remove the brazed rod end? Quote
MB65E Posted January 6, 2020 Report Posted January 6, 2020 I went through my steering horn. Replaced it with one I thought would be better too. Same slop, but now I know how it all works, and everything is fresh. I found a vendor for bushing stock and machined then for a better fit than what the factory could supply. -Matt 1 Quote
takair Posted January 6, 2020 Report Posted January 6, 2020 After various rebuilds over the years, I went for the LASAR STC upgrade kit a few years ago. So far it is holding up better than the original design. That said, I am convinced some of the slop is exaggerated by the less than optimal geometry in the linkage, even with the upgrade. It seems to be off from ideal by a few degrees and seems to input some angular movement at the steering arm. Anyway, before the LASAR kit, I seemed to be changing something every couple of years. I haven’t touched it in a few years now. Not cheap, but... Quote
Hradec Posted January 6, 2020 Author Report Posted January 6, 2020 On 1/6/2020 at 3:06 AM, MB65E said: I went through my steering horn. Replaced it with one I thought would be better too. Same slop, but now I know how it all works, and everything is fresh. I found a vendor for bushing stock and machined then for a better fit than what the factory could supply. -Matt Expand I would love to know who your bushing vendor is. Thanks Glenn 1 Quote
Yetti Posted January 6, 2020 Report Posted January 6, 2020 On 1/6/2020 at 3:01 AM, Hradec said: So the brazed one is an actual Mooney part! Seems like you could get a lot more life out of the brazed one. The current replacement is a joke, it's a $45 rod end with a $100 hole drilled in it. No support, drilled hole shortly goes oblong. Imagine a solid rod end with machined flats with washers brazed on. Has to last a bit longer than what is offered today. What year and type of mooney did you remove the brazed rod end? Expand Y'all keep saying brazed. It looks like the part is cast that way. But would not be hard to braze washers on. put a rod through to center the washers and clamp in vice and get to brazing. Quote
Hradec Posted January 7, 2020 Author Report Posted January 7, 2020 On 1/6/2020 at 8:47 PM, Yetti said: Y'all keep saying brazed. It looks like the part is cast that way. But would not be hard to braze washers on. put a rod through to center the washers and clamp in vice and get to brazing. Expand Looks like newer mooney part has teflon in the rod end. Probably not a good idea to braze. Quote
Yetti Posted January 7, 2020 Report Posted January 7, 2020 On 1/7/2020 at 4:31 AM, Hradec said: Looks like newer mooney part has teflon in the rod end. Probably not a good idea to braze. Expand Looks like rolling your own hemi joint is a thing. Weldable, rebuildable, greaseable https://www.emfrodends.com/collections/emf-heim-joints 1 Quote
Ragsf15e Posted January 25, 2023 Report Posted January 25, 2023 On 1/5/2020 at 11:47 PM, Hradec said: I'm trying to resurrect my 64 m20e serial #311. Hasn't flown in 4 yrs. Lots of play in the nose wheel, logs show a fairly recent overhauled lasar steering horn installed. That part is ok. However it was parked outside tail into the wind with no rudder lock. The rod ends took a beating. Examining the steering horn assy, looks like most of the play was in the upper center rod end. Looked pretty cheesy, hollow rod end with a hole drilled in it. Appears that that hole double or tripples the price of that rod end. IPC 203 part number 720014, IPC 205 part number 914012-013. IPC 202 shows it, but no part number. While doing a google search, I found a part at texas salvage that looked like a better older style part, today being substituted with a lesser part with a hole drilled in it. The "better" part is also worn, but I would like to find a new part like this. This part on the ball bushing has written heim F31-14a Mooney 914030. Has flat spots machined to the sides and 2 washers brazed. Looks like it would wear better than the part number used today, the new one just flops around orcwill shortly after installation. Any thoughts opinions? Get a regular rod end an modify? Is this an original part before cost savings were implemented? Thanks Glenn Expand Did you ever find a new 914012-013? mine is developing some slop too and I haven’t found one yet. Call is in to Lasar, but doesn’t look good from their website… Quote
