brndiar Posted November 21, 2019 Report Posted November 21, 2019 Hi. Does anyone have experience with 3 Blatt McCauley Propeller? In Schopp i was toiled that 3 blatt is better. Have to change from Hartzell 2Blatt. Thanks, Milos Quote
Hank Posted November 21, 2019 Report Posted November 21, 2019 My 1970 C has a 3-blade Hartzell propeller. It was on the plane when I bought it, so I can't tell you about the difference. It's nice. Quote
jwarren2 Posted November 21, 2019 Report Posted November 21, 2019 I was always lead to believe the three blade is sexier on the ramp and gives better climb performance but the two blades is a "few" knots faster in cruise. Quote
KSMooniac Posted November 21, 2019 Report Posted November 21, 2019 It's heavier, more expensive, and has higher vibrations than any other option for a 360 Lycoming. Check your CG and see what it does to your plane before you decide.Sent from my LG-US996 using Tapatalk 1 Quote
Hank Posted November 21, 2019 Report Posted November 21, 2019 1 hour ago, jwarren2 said: I was always lead to believe the three blade is sexier on the ramp and gives better climb performance but the two blades is a "few" knots faster in cruise. CG is a little further forward, but I've never had problems because of it. It was dynamically balanced at install, and I checked it 12 years later, still at 0.01 ips. I cruise at 7500-10,000 msl at 145-148 KTAS, lots of photos posted here already. Quote
David Lloyd Posted November 21, 2019 Report Posted November 21, 2019 When my 3 blade McCauley was installed many years ago, the battery was moved from the firewall to behind the cargo bulkhead. Solo, at light weights, the CG is right at the forward limit. Quote
Captnmack Posted November 22, 2019 Report Posted November 22, 2019 11 hours ago, brndiar said: Hi. Does anyone have experience with 3 Blatt McCauley Propeller? In Schopp i was toiled that 3 blatt is better. Have to change from Hartzell 2Blatt. Thanks, Milos To bad you are in Europe, I have one for sale! Quote
brndiar Posted November 22, 2019 Author Report Posted November 22, 2019 Thanks, In POH there is NO W$B. In attachement is what I use. Is there any "official" W&B for M20? Milos. Quote
carusoam Posted November 22, 2019 Report Posted November 22, 2019 The official WnB was done on a piece of paper and placed in the logs... it often got lost as it looked unofficial... As far as knowing the stations for pilots, back seat, baggage and hat rack, and fuel... That is the classic FAA M20 document that defines all the various Mooneys ever built... Search on weight and balance M20B,C,D,E... all the short bodies will have the same stations... The front seats are allowed to move on the rails... everything else is fixed.... Expect that everything will be in inches and pounds for the original format... wait for somebody else to share better detail... A lot is easy to share since many of us are using fore flight or WnB... and classic excel... Best regards, -a- Quote
Hank Posted November 22, 2019 Report Posted November 22, 2019 All distances (arms) are in the Type Certificate, including each position that the front seats can lock into. You should have a document listing the empty weight and CG of your particular airplane. Then add passenget weights, baggage and recalculate CG. 1 Quote
DMM Posted November 22, 2019 Report Posted November 22, 2019 A 3 blade McCauley was installed prior to my purchase. I have no complaints. It is heavier and the RPM limitations are different. According to my logs a Hartzell HC-C2YK-1 2-blade was removed (weight 57 lbs arm -30.16 inches). A McCauley prop B3D36C424/74SA weighing 71.3 (same arm) was installed. Tach marking changed: Green Arc - Normal 2200 to 2700 RPM, Yellow Arc - Caution 1650 to 2200 RPM Placard installed: "Avoid continuous operation below 15" M.P. setting between 1650 and 2200 RPM when above 85 KIAS (100 MPH). PO also installed a lightweight starter and alternator so the weight gain was offset. Quote
brndiar Posted November 22, 2019 Author Report Posted November 22, 2019 2Blade Hartzell proop (Hartzell HC-C2YK Hub with 1/7666-2 blade ist (in my case was) most effective bei 2500 RPM. Is there "most effective" RPM recommendation for 3 Blade McCauley Prop? Thanks,milos Quote
luv737s Posted November 22, 2019 Report Posted November 22, 2019 Previous owner installed 3 blade for Ground Clearance (makes a difference) and climb performance. However the added weight did shift the CG forward to the point that I carry 70 LBS of ballast to keep it in the envelope. Battery is still forward. 1 Quote
Hank Posted November 22, 2019 Report Posted November 22, 2019 2 hours ago, luv737s said: Previous owner installed 3 blade for Ground Clearance (makes a difference) and climb performance. However the added weight did shift the CG forward to the point that I carry 70 LBS of ballast to keep it in the envelope. Battery is still forward. Blade length, and therefore ground clearance, is the same for 2-blade and 3-blade props on our Mooneys. 1 Quote
MICKEY Posted November 22, 2019 Report Posted November 22, 2019 (edited) Rumor has it, it also crushes your glide ratio in an engine out. This adds up to 200fpm decent. Cruising at 8k AGL and Vg of, it can make you lose 2.5 Minutes of air time or 4 SM miles of Distance at 104mph. Edited November 22, 2019 by MICKEY Quote
Hank Posted November 22, 2019 Report Posted November 22, 2019 6 minutes ago, MICKEY said: Rumor has it, it also crushes your glide ratio in an engine out. This adds up to 200fpm decent. Cruising at 8k AGL and Vg of, it can make you lose 2.5 Minutes of air time or 4 SM miles of Distance at 104mph. Pull the prop ba k to coarse pitch / low RPM will make a huge difference. I've never had a problem with glide distance with mine. And I generally ignore rumors. 1 Quote
MICKEY Posted November 22, 2019 Report Posted November 22, 2019 3 minutes ago, Hank said: Pull the prop ba k to coarse pitch / low RPM will make a huge difference. I've never had a problem with glide distance with mine. And I generally ignore rumors. I agree. I don't think it is "Rumor", more... statistically speaking it would increased drag, due to more surface area. Just Food for thought. I don't think Id change the number prop blades based on single engine out performance. Quote
KSMooniac Posted November 22, 2019 Report Posted November 22, 2019 Blade length, and therefore ground clearance, is the same for 2-blade and 3-blade props on our Mooneys. This is true except for the MT... It is actually a smaller diameter than all of the metal options. And much lighter and smoother.Sent from my LG-US996 using Tapatalk Quote
Oscar Avalle Posted November 25, 2019 Report Posted November 25, 2019 I have a three blade on my M20C 1970. Looks nice, it came with the plane, but I would prefer a two blade. Quote
pirate Posted November 26, 2019 Report Posted November 26, 2019 I replaced my two blade several years ago for a three blade. I noticed no real airspeed decrease. Climb is much much better on hot days,. ( main reason for upgrade ) I experienced no vibration problems. Make sure to have balanced once installed. My glide is not reduced. A tad more nose heavy but a light weight starter, alternator really helps. 1 Quote
