FloridaMan Posted October 25, 2019 Report Posted October 25, 2019 (edited) I hate the glass on my Rocket. It’s a tad foggy and tinted. Compared to my m20f which is crystal clear and enjoyable to look out of. The concern I have with going to clear is UV exposure up in the flight levels. I’m thinking of cutting reusable stick-on tint panels to size and installing them so I can have both some tint, but also enjoy the views at night and when sight-seeing down low. The current tinting in the Windows is inadequate for flying over cloud tops at 240. Thoughts? Edited October 25, 2019 by FloridaMan Quote
EricJ Posted October 25, 2019 Report Posted October 25, 2019 The other thing to think about is heating on the ground (solar gain). My airplane has the grey tinted glass and it stays reasonable longer when sitting in the sun compared to an airplane with clear, which can turn into an oven in short order. Even with the grey tint I keep the static sticky dark tint around to place as needed if the sun is in an unfavorable spot. When I fly in other airplanes with clear glass I'm thankful for my tint. 2 Quote
FloridaMan Posted October 25, 2019 Author Report Posted October 25, 2019 4 minutes ago, EricJ said: The other thing to think about is heating on the ground (solar gain). My airplane has the grey tinted glass and it stays reasonable longer when sitting in the sun compared to an airplane with clear, which can turn into an oven in short order. Even with the grey tint I keep the static sticky dark tint around to place as needed if the sun is in an unfavorable spot. When I fly in other airplanes with clear glass I'm thankful for my tint. Being in Florida, it doesn’t seem to matter. Hopefully in a month or two I’ll have my air conditioning ready for testing. Quote
TTaylor Posted October 25, 2019 Report Posted October 25, 2019 I highly recommend the solar gray tint. Provides UV protection, cooler interior in summer, and the optics are crystal clear. Almost no noticeable reduction in visibility for night flight. Best solution for aircraft windows right now. 1 Quote
takair Posted October 25, 2019 Report Posted October 25, 2019 I went from foggy green tint to clear while living in Georgia. I regretted it almost immediately. The sun is noticeably hotter. Even here in New England I regret it. I’ve added the removable tint to the rear windows, but find it too dark for the front, plus the optics are not quite perfect. The only time I really am happy with the clear glass is if flying low during leaf season, which amounts a a few flights each year. Quote
larrynimmo Posted October 25, 2019 Report Posted October 25, 2019 I’ve ordered the green UV protected windshield....why....because I flew with a friend in a beech muskateer that felt at least 10 degrees warmer with the clear plexi...it was so hot even on an 80 degree day Quote
Browncbr1 Posted October 26, 2019 Report Posted October 26, 2019 +1 for solar grey uv. No problems at night. Quote
Htwjr Posted October 26, 2019 Report Posted October 26, 2019 I replaced my side windows using solar grey on the front ones and dark tint on the rear and was suprised how much cooler the plane was and how much cooler and more modern it looked. My old ones were badly crazed which made taxiing at night difficult. +2 for solar grey Quote
carusoam Posted October 26, 2019 Report Posted October 26, 2019 Went from old faded green to clear in the door window... Reminded me of sitting in the back of mom’s 70s station wagon... noticeably too hot and stuffy... Went back to green a week later... slowly changing one window at a time... +1 for solar gray... +1 See if you can get UV resistant clear... modern chemistry... +1 having a hangar... Best regards, -a- Quote
rbridges Posted October 26, 2019 Report Posted October 26, 2019 14 hours ago, TTaylor said: I highly recommend the solar gray tint. Provides UV protection, cooler interior in summer, and the optics are crystal clear. Almost no noticeable reduction in visibility for night flight. Best solution for aircraft windows right now. I've never flown in a plane with the solar gray, but it looks nice from the outside. Quote
GeeBee Posted October 26, 2019 Report Posted October 26, 2019 I have a few thousand hours in the flight levels with clear windows above the arctic ice. There is NO tint that can save your skin or keep you comfortable. I have tried them all. Amber, green, grey. Put on a lot of sunscreen and stuff a chart in the frame to block the direct sun. You are in the flight levels (positive control airspace) and you have a traffic display. See and be seen is not a factor. Quote
FloridaMan Posted October 26, 2019 Author Report Posted October 26, 2019 I honestly don’t really notice any difference between my two planes in Florida. Tint or no tint, it’s hot. On the ground, the cool scoop makes the biggest difference. Quote
Immelman Posted October 26, 2019 Report Posted October 26, 2019 Get the UV protected ones. I went clear, and the view is nice, but I wish I had UV protection. Hindsight 20/20 I made a mistake. I don't care for the ones that are blue or green, but neutral gray UV..... the colors will still be real outside. 1 Quote
Yetti Posted October 26, 2019 Report Posted October 26, 2019 Consider upgrading to Windows 10 seems to be more stable. 1 2 Quote
ArtVandelay Posted October 27, 2019 Report Posted October 27, 2019 Here is what the extra dark gray looks like:Tom Quote
FloridaMan Posted October 27, 2019 Author Report Posted October 27, 2019 7 hours ago, ArtVandelay said: Here is what the extra dark gray looks like: Tom Any chance you could post a photo from the inside or of the door open for contrast with the outside? Every photo I see of gray I’m looking through two windows. Quote
ArtVandelay Posted October 27, 2019 Report Posted October 27, 2019 Any chance you could post a photo from the inside or of the door open for contrast with the outside? Every photo I see of gray I’m looking through two windows. Will do.Tom Quote
ArtVandelay Posted November 2, 2019 Report Posted November 2, 2019 Any chance you could post a photo from the inside or of the door open for contrast with the outside? Every photo I see of gray I’m looking through two windows. Here you go:Tom 1 Quote
81X Posted November 3, 2019 Report Posted November 3, 2019 I went solar gray from LP Aero when I re-did my Cherokee glass except for the windscreen which was UV-coated clear. It looked a lot more modern than green and it certainly helped to block some of the heat. No issues at night whatsoever and if I ever re-do my 231, I'll do exactly the same. I use some of those sticky small tint panels now for my kid in the back which help for now. Quote
