Gary0747 Posted October 19, 2019 Report Posted October 19, 2019 I keep getting an occasional report on Flightaware of my airplane making flights in and around the New York State area. I suspect they have mistakenly entered my FAA ADSB hex code. I am looking for suggestions on how to locate the owner or report it to the FAA. Hopefully they will not commit any airspace violations using my ID. Here is the most recent flightaware track that was made with my aircraft ID. https://flightaware.com/live/flight/N9562M/history/20191013/2207Z
RLCarter Posted October 19, 2019 Report Posted October 19, 2019 What shows the ADS-B info, only see a reg#
ilovecornfields Posted October 19, 2019 Report Posted October 19, 2019 I would call those guys from Airplane Repo. They seem pretty good at tracking down planes... Did you try calling FSDO?
Gary0747 Posted October 19, 2019 Author Report Posted October 19, 2019 It only lists my N number and my registration I don’t see any way to find out who they are unless they file an IFR flight plan. I am see this as a position only flight. No flight plan I will contact my FISDO but hate getting them involved unless that is the only way.
flight2000 Posted October 19, 2019 Report Posted October 19, 2019 Someone fat fingered your tail number when they did flight following. If you look at the track log it shows the actual TRACON and Center (photo 1). Compare that to a VFR flight I did on Monday that shows ADSB tracking (photo 2). Cheers, Brian Photo 1: Photo 2: 1
flight2000 Posted October 19, 2019 Report Posted October 19, 2019 (edited) I reversed a few numbers and found an aircraft with a lot of flights in New York...N9526M...and it's also an M20F...go figure... Brian Edited October 19, 2019 by flight2000 1 1
RLCarter Posted October 19, 2019 Report Posted October 19, 2019 19 minutes ago, flight2000 said: I reversed a few numbers and found an aircraft with a lot of flights in New York...N9526M...and it's also an M20F...go figure... Brian It happens more than you'd think... Was tracking a buddy in his "C", couldn't find his tail number in the system, but there was a C-150 that just left the same airport, transposed numbers clicking along at 150+ knots
bradp Posted October 19, 2019 Report Posted October 19, 2019 I apologize in advance to 201GH or 201HQ
Gary0747 Posted October 19, 2019 Author Report Posted October 19, 2019 Thanks Brian, it appears you figured it out. Somebody is transposing those last two numbers and it has apparently happened at least two other times before since all the mistaken flights have occurred in this same geographic area. He apparently does not have ADSB out yet and is only using flight following. I wonder if this kind of error will be caught when the ADSB data can be compared to the N number that the controller types in?
Davidv Posted October 19, 2019 Report Posted October 19, 2019 It's surprising how easy it is to change the hex code in my GNX-375. For me it happened when my shop installed a new garmin encoder which was previously configured to another aircraft. Apparently this changed the code in my setup and I had been broadcasting the tail number of this other aircraft for a few flights. I just went into the setup and changed the code to mine. It would seem pretty easy for a bad actor to pick that guy on the field he doesn't like and then go bust a bravo with his code... 1
gsxrpilot Posted October 19, 2019 Report Posted October 19, 2019 The same thing happens to me as well. There's someone in Mississippi flying a B55 with tail number N525DD. He's obviously a bit dyslexic and always gets it mixed up to N252AD. I get pinged all the time by people asking if I'm in Mississippi.
1964-M20E Posted October 19, 2019 Report Posted October 19, 2019 This adds plausible deniability when some asks why you flew here or there?
neilpilot Posted October 19, 2019 Report Posted October 19, 2019 A while back an aircraft on the west coast was squawking my ADS-B. After several flights I was able to determine their base. I called several Avionics shops in the general area and finally talked to one who suspected a recent installation. Turns out after we returned a loaner KT74 to BK they sent it to another customer without wiping my code. Of course the shop that installed the unit failed to setup the unit as well. During my attempt to track down the culprit I did call the FAA. A wasted call.
Jerry 5TJ Posted October 19, 2019 Report Posted October 19, 2019 How about asking the FAA to assign you a new ICAO code? This reminds me I need to de-configure the GTX33ES just pulled from my plane that I have for sale.
Yetti Posted October 19, 2019 Report Posted October 19, 2019 Hex is hard. I used to be able to add subtract and convert binary in my head. lost skills
Oldguy Posted October 20, 2019 Report Posted October 20, 2019 Yeah, I love how we enter an octal squawk code to match up with a hexadecimal one for our plane. Univac to IBM integration anyone? 1
carusoam Posted October 21, 2019 Report Posted October 21, 2019 On the human brain side... the middle two digits of a four digit number get swapped around quite frequently... Not sure why, but if you get a four digit number wrong... swap the two middle ones and see if that helps... Best regards, -a-
Lionudakis Posted October 27, 2019 Report Posted October 27, 2019 Someone in south america dings my tail number N51CT. They're usually around 240kts at 20k.... I wish
eman1200 Posted October 27, 2019 Report Posted October 27, 2019 Happened to me yesterday. A bud txted me saying “are u flying in Texas??” Nope, no I wasn’t, but sure as sht Flightaware had me zooming around TX.
