Can anyone ID this type of probe  Its is for the factor TIT and CDT. Roughly 1.25" exposed and .25 wide. I need 2. One for the old factory TIT and one for CDT.
thanks
Thanks
You might tell us exactly what plane it is on. Did you look in the Mooney parts manual? I guess you are looking for an OEM replacement part. Otherwise just call laser and order them.What is wrong with them?
The one on the left appears to be the original TIT probe, the one on the right is a JPI probe.  The band clamp looks to have holes to accept them both.  I’ve seen this method before.
OK,
It is a 1980 231K. You are correct.. This is a OEM probe. The problem is that neither the ship's TIT or CDT work. The gauge is a B&D instruments Valley Center Kansas. I will look for a wiring schematic and ck it is getting power. Continuity from probes to gauge is good. The wires to gauge are not a home run. There is a screw/bolt connection, then thru firewall.
Anybody have a wiring pic for that instrument? Lookslike about 6 pins are used.
Tks
2 hours ago, willerjim273 said:
 I’ve seen this method before.   ?
Yes, where a band clamp has been modified to allow use of 2 TIT probes in the same location of the transition pipe.
I don’t know what you serial number is, or if this wiring schematic will be clear enough.
6 hours ago, carusoam said:
+1 on ThinWing’s observation...
If i’m Seeing the same thing he is...
I circled it in red...
@willerjim273 and @M20Doc is that a leak, and how important is that?
PP concern only, not a mechanic...
In the shop we use an old Filter Queen vacuum cleaner with the hose on the discharge side and a plug to connect to the tail pipe to pressurize the exhaust system to find leaks.
Exhaust system V band clamps have a short life of generally 2 installations and retorqing.  The K model manual doesn’t restrict it, but it’s worthy of consideration.
