Niko182 Posted April 13, 2019 Report Posted April 13, 2019 1 minute ago, Brian E. said: And do you need a stand alone/new CDI to use with the 375? Provided you have no other existing glass of course. Most of the time you add a relay switch that differentiates gps from nav and that just hooks up to the hsi. So it would be hooked up to your hsi in most cases, and you switch between gps and nav.
Brian E. Posted April 13, 2019 Report Posted April 13, 2019 5 minutes ago, Niko182 said: Most of the time you add a relay switch that differentiates gps from nav and that just hooks up to the hsi. So it would be hooked up to your hsi in most cases, and you switch between gps and nav. I"m all classic steam gauges with only a DG...
Niko182 Posted April 13, 2019 Report Posted April 13, 2019 10 minutes ago, nels said: Thanks, Ross. Any idea on install price? I got 22 hours from chandler, 40 from howard, and like 43 from lasar. I just booked a slot in december for a gnx375, a g3x 10.6 with eis, and a gfc500. 1
Niko182 Posted April 13, 2019 Report Posted April 13, 2019 18 minutes ago, Brian E. said: I"m all classic steam gauges with only a DG... whats your current setup of a panel? you have a picture?
LANCECASPER Posted April 13, 2019 Report Posted April 13, 2019 38 minutes ago, Niko182 said: I got 22 hours from chandler, 40 from howard, and like 43 from lasar. I just booked a slot in december for a gnx375, a g3x 10.6 with eis, and a gfc500. Do you mind sharing the total quote?
Niko182 Posted April 13, 2019 Report Posted April 13, 2019 20 minutes ago, LANCECASPER said: Do you mind sharing the total quote? My guess is around 45k to 50k but i should be getting the quote monday or tuesday. 1
Brian E. Posted April 13, 2019 Report Posted April 13, 2019 1 hour ago, Niko182 said: whats your current setup of a panel? you have a picture? Old school original...
Niko182 Posted April 13, 2019 Report Posted April 13, 2019 24 minutes ago, Brian E. said: Old school original... In this case, you'd add a relay switch in between the CDI and the Nav/comm. And you'd hook up the relay switch to the GPS and the Nav. That switch would decide what would be displayed on the CDI. And make sure you use the CDI with GS. that will allow you to use LPV approaches. so for example if you want to do an ILS, you would select nav on the relay switch, and input the localizer frequency. if you wanted the to do an LPV approach, you'd put the switch to GPS, load the approach, and do the approach. while you're installing that, take an additional 500 to 800 bucks and cut a new panel out. IFR flying with a conventional panel is much easier than with a shotgun panel.
carusoam Posted April 13, 2019 Report Posted April 13, 2019 Jerry, Can you find a ground station broadcasting LORAN signals..? I’m going to ask Alexa... you might remember these details... https://www.gps.gov/policy/legislation/loran-c/ Best regards, -a-
Brian E. Posted April 13, 2019 Report Posted April 13, 2019 The LORAN unit does work (at least it turns on). It tells me the database is woefully out of date... I'll make you a deal on it! 1
johncuyle Posted April 14, 2019 Report Posted April 14, 2019 15 hours ago, carusoam said: Jerry, Can you find a ground station broadcasting LORAN signals..? I’m going to ask Alexa... you might remember these details... https://www.gps.gov/policy/legislation/loran-c/ Best regards, -a- Isn't E-Loran a thing in South Korea thanks to North Korean GPS spoofing/jamming? Maybe the FAA will mandate equipage for Next-Previous-Gen, after everyone has ADS-B and they're looking for something to do. The old Loran-C units will still probably only be useful as paperweights then anyway.
McMooney Posted April 14, 2019 Report Posted April 14, 2019 45 minutes ago, johncuyle said: Isn't E-Loran a thing in South Korea thanks to North Korean GPS spoofing/jamming? Maybe the FAA will mandate equipage for Next-Previous-Gen, after everyone has ADS-B and they're looking for something to do. The old Loran-C units will still probably only be useful as paperweights then anyway. If I remember correctly, the faa may be thinking of reintroducing a loran type service.
kortopates Posted April 17, 2019 Report Posted April 17, 2019 If I remember correctly, the faa may be thinking of reintroducing a loran type service. It's being considered as they look to replace VOR's with a more affordable cost solution as a backup to GPS. I suspect their intended date on that will slip big time!Sent from my iPhone using Tapatalk
