Airways Posted December 4, 2018 Report Posted December 4, 2018 I love Mooney but I’m not a big fan of the performance charts in the (copy of a copy of a copy) POH. Does anybody know if there are excell files/apps/... for a M20K 252 that can be used for performance calculation/W&B ? Thanks ! Quote
gsxrpilot Posted December 4, 2018 Report Posted December 4, 2018 I can make you a copy of my POH But seriously, I don't know of any. Is there a specific question about performance/W&B you have? Mine is always flown on the heavy side of the chart. Quote
Airways Posted December 4, 2018 Author Report Posted December 4, 2018 Not a particular problem but I’m transitioning from a J to a K which means I’d like to make thorough performance and WB calculations before every departure, especially the first couple of flights... Quote
carusoam Posted December 4, 2018 Report Posted December 4, 2018 Somebody went through the effort doing exactly this... ... for the Ovation. Performance calculations using excel and dropped into iOS using an app.... This way the copy of a copy is electronic and not very noticeable to how many times it has been copied! Great question to ask to an MSC/Mooney directly... Best regards, -a- Quote
gsxrpilot Posted December 4, 2018 Report Posted December 4, 2018 On 12/4/2018 at 6:44 PM, carusoam said: Somebody went through the effort doing exactly this... ... for the Ovation. Performance calculations using excel and dropped into iOS using an app.... This way the copy of a copy is electronic and not very noticeable to how many times it has been copied! Expand Hmmmm.... maybe someone should do that for the beloved 252. Quote
gsxrpilot Posted December 4, 2018 Report Posted December 4, 2018 On 12/4/2018 at 6:36 PM, Airways said: Not a particular problem but I’m transitioning from a J to a K which means I’d like to make thorough performance and WB calculations before every departure, especially the first couple of flights... Expand 3000 ft of runway and no more than 100 lbs or so over gross and you'll be fine. She should climb easily at 700 ft/min even at gross all the way to the flight levels. Or at least this is what I've heard 1 Quote
WilliamR Posted December 4, 2018 Report Posted December 4, 2018 Funny, this has been my on again off again project for some time. It's been fun and a good challenge to my excel modeling skills. I've completed the take-off performance calcs and have moved on to landing distances. I looked at the Oviation one provided and it was very good and probably could be deconstructed and manipulated. Of course, I like mine better. I probably shouldn't even provide this given it's a work in progress and not ready for prime time, but here goes. Unfortunately, between deal flow at work, flying part time and moving to a new home and moving the airplane, this has fallen to the bottom of my list since last May. It's been fun creating the calculations as the slopes are increasing or decreasing as the case may be based on temp. wind etc. The upside is that the slopes in the chart do seem to be linear. Of course, there are the usual stipulations, your POH is the governing document and should always be consulted, blah, blah, blah. I do find it ridiculous that you could be a pencil lead width off and that's 50 ft. But, I guess that goes under the heading of measuring with a micrometer and cutting with an axe. No one cuts it 50 ft close when determining needed runway length. Copy of MasterCalc - Mooney 252 draft 5-23-18.xls 2 Quote
gsxrpilot Posted December 4, 2018 Report Posted December 4, 2018 On 12/4/2018 at 10:28 PM, WilliamR said: Funny, this has been my on again off again project for some time. It's been fun and a good challenge to my excel modeling skills. I've completed the take-off performance calcs and have moved on to landing distances. I looked at the Oviation one provided and it was very good and probably could be deconstructed and manipulated. Of course, I like mine better. I probably shouldn't even provide this given it's a work in progress and not ready for prime time, but here goes. Unfortunately, between deal flow at work, flying part time and moving to a new home and moving the airplane, this has fallen to the bottom of my list since last May. It's been fun creating the calculations as the slopes are increasing or decreasing as the case may be based on temp. wind etc. The upside is that the slopes in the chart do seem to be linear. Of course, there are the usual stipulations, your POH is the governing document and should always be consulted, blah, blah, blah. I do find it ridiculous that you could be a pencil lead width off and that's 50 ft. But, I guess that goes under the heading of measuring with a micrometer and cutting with an axe. No one cuts it 50 ft close when determining needed runway length. Copy of MasterCalc - Mooney 252 draft 5-23-18.xlsFetching info... Expand Thanks! Quote
81X Posted December 10, 2018 Report Posted December 10, 2018 On 12/4/2018 at 6:50 PM, gsxrpilot said: 3000 ft of runway and no more than 100 lbs or so over gross and you'll be fine. She should climb easily at 700 ft/min even at gross all the way to the flight levels. Or at least this is what I've heard Expand Ah yes, when you’re running a part 121 flight in Alaska. Carry on then! Quote
gsxrpilot Posted December 11, 2018 Report Posted December 11, 2018 On 12/10/2018 at 11:29 PM, 81X said: Ah yes, when you’re running a part 121 flight in Alaska. Carry on then! Is the OP doing that? Quote
