Anyone else have a quick drain on their engine?  I went to change the oil today, drained out all the oil, changed the filter, started pouring in new oil.  Got about 3qts in when I saw that the oil drain was leaking out oil.  Guess I need a new one of these.  Is this something I can replace myself, or do I need an A&P to sign off on it?
Interesting question.  Since the FAR's allow an owner to do an oil change, I would opine that an owner could replace the quick drain since it is essentially just a fancy oil drain plug.
However, if you make a log-book entry about the quick drain, it may require an A&P sign off.  I'm a pilot, not an IA.  My opinion is worth less than you paid for it.
My hangar elf suggest that when you install the new quick drain, put some anti-seize on the threads.  They can be tough to remove.
I would take it out and clean it.  The is either something stuck in the O ring or it is damaged.  As I recall the earlier red coloured ones have only 1 “O”ring where the newer blue ones have dual “O” rings.
You’ll also need a new MS35769-11 or AN900-10 copper gasket to reinstall it.
I wish somebody made a quick drain like the Fumoto drain valve for auto engines.  I like that it requires two movements to open, as opposed to a push-open movement.
They seem to get installed with sticky stuff.   A heat gun seemed to aid in the removal. reinstall with some permetex
Guest tommy123
They get safety wired. Don’t glop sealant  on things that aren’t supposed to get sealant. A&P IA opinion. Jeez.
Each Saf-Air oil drain valve that I’ve installed comes with a small tube of thread sealant/lubricant to be applied to the threads.
Perhaps you never installed one or read the instructions?
The irrelevance of the safety wired is implied in the name of safety wire.   Let's see aluminum fitting on what looked to be steel pipe with NPT threads.  Do you think you can get NPT threads tight enough to not leak without compromising the aluminum fitting?
The OP’s F model has been modified by installation of an IO-360ES engine.  It’s oil sump should have straight cut 5/8-18 threads.  Use of thread sealant/ lubricant helps avoid galled/ damaged aluminum threads in the sump and valve.
The Curits valves are great. Their large one I have on the Mooney oil sump. Simple device, about 3 years ago they changed the o-ring material and it’s now approved for oil.
-Matt
I think @jlunseth may have some funky oil drain experience?
My memory is not so good. So I may have swapped some important detail...
when doing a search also include quick drain with your search... a name that gets used to describe this thing...
I don’t think you’re losing it, I too remember a post here about oil loss caused by contamination in the drain seal and an unscheduled landing in Canada?
Yes, that was me alright.  Just a sliver of plastic about 3/8” long and maybe 1/16-1/8 thick as I recall.  I kept it, I still have it somewhere.  It went in the quick drain entrance hole but did not pass through, kept the valve from completely sealing.  Running the engine pressurizes the crankcase so we blew out about 4-5 qts over a couple of hours.  Got to visit Canada without intending to.
Be careful with those things.  At a minimum, disassemble and clean it and put in a new “kit” which includes the O riong(s).
Took off the quick drain, looked like there was a little piece of gasket stuck in the entrance hole.  Replaced the o-rings and used a wire brush to clean up all the caked on oil.  I could tell there is a lot more resistance from the new o-rings when pulling the drain now.  The quick drain o-rings are definitely something that is going on the annual checklist.
