0TreeLemur Posted March 29, 2019 Author Report Posted March 29, 2019 @hmasing what size drill did you use for the window mounting holes? I've read that oversized is good, some say 3/16", but I've also read 1/4". Do those holes require a 100-degree countersink? I haven't ordered plastic drill bits yet. Quote
0TreeLemur Posted April 1, 2019 Author Report Posted April 1, 2019 On 3/27/2019 at 2:37 PM, SheryLoewen said: DRILLING TIP NOTE: Windshields installed with flush screws through dimpled holes in the skin need special attention. When drilling the Plexiglas being held in place, the windshield will be resting against the dimpled upset-holding it slightly out of position. To compensate for this, the pilot holes #40 should be drilled to the outside edge of the existing holes. They will lineup after the hole is drilled full size and countersink! This prevents puckering of the metal on the finished job. Shery/Paul thanks so much. This is extremely important to know! Quote
0TreeLemur Posted April 12, 2019 Author Report Posted April 12, 2019 On 9/3/2018 at 3:56 PM, cliffy said: Yes OK for owner maintenance, must be signed off correctly , by the owner doing the work, with name , pilot lic. number, date, hours and what was done and reference the proper section of 43.13 that lists what an owner can do. You technically need the maintenance manual at hand while you do the work. Plexi drill bits can be bought or made by grinding the leading edge of the cutting point paralleled to the length of the drill so it doesn't dig into the plexi. Again, technically, if you use a thicker plexi for replacement you "technically" are making a change to the type design of the airplane that goes into a "minor alteration" of the airplane and that needs a real A&P for sign off-"TECHNICALLY" Any band saw blade used in cutting plexi should have a very fine tooth spacing. A wood cutting blade may/will crack and break the plexi. @cliffy a search through the Mooney M20 maint. manual PDF for the words "window"and "windshield" turned up nothing about window replacement. This weekend I'm going to replace the door window. The old one is soooo bad it must be the '67 original. Quote
0TreeLemur Posted April 14, 2019 Author Report Posted April 14, 2019 On 3/27/2019 at 2:37 PM, SheryLoewen said: DRILLING TIP NOTE: Windshields installed with flush screws through dimpled holes in the skin need special attention. When drilling the Plexiglas being held in place, the windshield will be resting against the dimpled upset-holding it slightly out of position. To compensate for this, the pilot holes #40 should be drilled to the outside edge of the existing holes. They will lineup after the hole is drilled full size and countersink! This prevents puckering of the metal on the finished job. Your recommendation worked out great! I noticed after removing the old window that if you lay one on top of the other, they appear do be different sizes relative to each other depending upon which one is on top. This means that using one to mark the hole locations in the other is not really possible. Your technique eliminated that problem while accounting for the curvature issue. I really appreciate your advice. 1 Quote
0TreeLemur Posted April 15, 2019 Author Report Posted April 15, 2019 The end result - before and after photo. There is a new window in the door, it is just so clear compared to the old one that it seems invisible 2 Quote
carusoam Posted April 15, 2019 Report Posted April 15, 2019 Great details, Fred! Thanks for sharing them. The old window appears to have changed colors a bit... comparing to the edges. nice pic. Best regards, -a- Quote
0TreeLemur Posted April 15, 2019 Author Report Posted April 15, 2019 8 hours ago, carusoam said: Great details, Fred! Thanks for sharing them. The old window appears to have changed colors a bit... comparing to the edges. nice pic. Best regards, -a- Yes, the part that was exposed to the sun is badly crazed, while the edge is not nearly so. The edge was inflexibly clamped, while the center probably experienced a lot of vibrational motion. So, I leave it to you to say if it was UV exposure that weakened the material, vibration, or both that led to the changes in optical properties of the acrylic. Mixing and applying that polysulphide sealant reminded me of that old Cheech & Chong comedy routine featuring the two Russians: "Look Like Dog $#!%?". "Da. Smell bad too." We had a fun weekend. 1 Quote
1964-M20E Posted April 15, 2019 Report Posted April 15, 2019 16 hours ago, Fred₂O said: The end result - before and after photo. There is a new window in the door, it is just so clear compared to the old one that it seems invisible The only drawback is you will now need to use foggles when you ant to practice IMC flying. 1 Quote
cliffy Posted April 17, 2019 Report Posted April 17, 2019 At the airlines when we mixed that "stuff" up we did call it Dog S&^% ! 1 Quote
0TreeLemur Posted May 1, 2019 Author Report Posted May 1, 2019 Well we got the left-hand side window installed this past weekend. At the pace my co-pilot and I work, it takes most of a weekend to replace one window. I'll post our checklist items assembled from the advice received from MS members. Thanks to all who helped us figure out how to do this! As the photo shows, the new window (SG+UV) is reeeeealy nice. Can't wait to take her for a test flight. Quote
flyboy0681 Posted May 1, 2019 Report Posted May 1, 2019 21 minutes ago, Fred₂O said: Well we got the left-hand side window installed this past weekend. At the pace my co-pilot and I work, it takes most of a weekend to replace one window. I'll post our checklist items assembled from the advice received from MS members. Thanks to all who helped us figure out how to do this! As the photo shows, the new window (SG+UV) is reeeeealy nice. Can't wait to take her for a test flight. May want to treat the rust spots in the tubing while you have the panels off. Quote
flyboy0681 Posted May 1, 2019 Report Posted May 1, 2019 1 minute ago, Fred₂O said: Suggest a method? CorrosionX? I meant fix the rust spots. Rust only worsens over time. We've being using CorrosionX for years and when all of our panels were removed, there was nothing. And we are located in South Florida. Nuff said. Quote
Prior owner Posted May 1, 2019 Report Posted May 1, 2019 Just be careful scrapping the old sealant- it doesn’t take much pressure with a plastic scraper to distort the aluminum (bow it outwards permanently). Quote
0TreeLemur Posted May 1, 2019 Author Report Posted May 1, 2019 1 hour ago, PilotCoyote said: Just be careful scrapping the old sealant- it doesn’t take much pressure with a plastic scraper to distort the aluminum (bow it outwards permanently). We're done. Mostly the old sealant came off by pulling at corners and scraping with fingernails. That photo above shows the new window installed. 1 Quote
0TreeLemur Posted May 1, 2019 Author Report Posted May 1, 2019 2 hours ago, flyboy0681 said: I meant fix the rust spots. Rust only worsens over time. We've being using CorrosionX for years and when all of our panels were removed, there was nothing. And we are located in South Florida. Nuff said. Thanks- you suggested that we "treat" the rust spots in the tubing, and I was asking about how you would do that. My question was, should I just wipe on some CorrosionX and be done with it? Quote
Guest Posted May 1, 2019 Report Posted May 1, 2019 5 hours ago, Fred₂O said: Suggest a method? CorrosionX? Mooney S/B M20-208 covers the subject. Clarence Quote
0TreeLemur Posted May 1, 2019 Author Report Posted May 1, 2019 S/B M20-208 has been complied with. We plan to tackle the interior next, that will be a good opportunity to inspect the tubing, remove the surface corrosion and apply some primer before continuing. In the meanwhile, Corrosion-X it is. Quote
jaylw314 Posted May 1, 2019 Report Posted May 1, 2019 17 minutes ago, Fred₂O said: S/B M20-208 has been complied with. We plan to tackle the interior next, that will be a good opportunity to inspect the tubing, remove the surface corrosion and apply some primer before continuing. In the meanwhile, Corrosion-X it is. There's some info in SB M20-208 that describes procedures for how to treat corrosion on the structural tubing Quote
0TreeLemur Posted May 2, 2019 Author Report Posted May 2, 2019 1 hour ago, jaylw314 said: There's some info in SB M20-208 that describes procedures for how to treat corrosion on the structural tubing Gonna do use that procedure. Thx. Quote
