In an attempt to add heading info to my G5 AI, we are attempting to install the magnetometer. Alas, in doing the magnetic interference test all went well until the old Grimes coffee grinder beacon was turned on. The reasonable solution seemed to be swapping it for a solid state LED beacon. Unfortunately, it emits magnetic interference when it flashes. The power supply wire is shielded and the shield is grounded.
I’m putting this out there in case any “techies” have any suggestions. Ferrite bead?
If it’s coming up the power line Into the DC bus a large electrolytic capacitor on the +12v lead at the device and the other side to ground helps. Also run the - wire back to the battery.
Make sure the shield is only grounded at one end of the cable.  Don't bundle the  magnetometer wire with or near any other wires or coax. Wrapping the power lead to the light around split ferrit core might help. If it's still causing problems one of these or similar will likely fix the problem.  Place it close to the light .
https://lonestaraviation.com/product/faa-pma-eliminator-filter/
Good news, I think. Beacon had been grounded to adjacent airframe. A local airport EE ( who knew?) suggested running the ground back to the battery. That worked! At least in a jury rigged fashion. Make of that what you will, but the mag interference is now acceptable.
