Mooneycrazy Posted January 4, 2018 Report Posted January 4, 2018 My 66 M20F gear switch does operate, but the knob is loose and even when switched it is very sloppy..I did try to tighten the knob and just think its time for a new one .Does anyone know where to buy a replacement? Does someone make new ones? Thanks Quote
cbarnes403 Posted January 4, 2018 Report Posted January 4, 2018 I may have one, I'll look for it this weekend and let you know. Quote
DualRatedFlyer Posted January 4, 2018 Report Posted January 4, 2018 I would also like to know where these can be found. My is stripped and barely hanging on. Quote
Guest Posted January 5, 2018 Report Posted January 5, 2018 It should be a Micro 1TL140-3D according to the F parts catalog. Clarence Quote
Mooneycrazy Posted January 5, 2018 Author Report Posted January 5, 2018 Ok, thanks for that information......Any advice as to where to find one...? Quote
Guest Posted January 5, 2018 Report Posted January 5, 2018 20 minutes ago, Mooneycrazy said: Ok, thanks for that information......Any advice as to where to find one...? Google is your friend, enter the part number and Micro switch. You’ll find many. Clarence Quote
Mooneycrazy Posted January 5, 2018 Author Report Posted January 5, 2018 I was unable to find a switch like the factory one... Are you thinking it would have to be replaced with an aftermarket switch simluar...not sure I understand....I was thinking of a full replacement part from an aircraft parts supplier....After seeing all the Mooneys Ive seen...so many of the older ones looked in simluar condition.....I would think someone would have needed to replace theirs as well...? Quote
Ron McBride Posted January 5, 2018 Report Posted January 5, 2018 Try ebay. https://www.ebay.com/itm/Mooney-M20E-Landing-Gear-Position-Switch-P-N-1TL149-3D/331626161390?hash=item4d3675a4ee:g:bRQAAOSw9N1Vygvh&vxp=mtr Quote
Mooneycrazy Posted January 5, 2018 Author Report Posted January 5, 2018 saw this as well...Looks like the same old one I have....I Quote
