Joe Larussa Posted December 20, 2017 Author Report Posted December 20, 2017 8 hours ago, Brandontwalker said: +1. I had exact issue and it resolved with a notch filter. Easy fix. Sent from my iPhone using Tapatalk Okay I'm in!
Joe Larussa Posted December 20, 2017 Author Report Posted December 20, 2017 8 hours ago, Brandontwalker said: +1. I had exact issue and it resolved with a notch filter. Easy fix. Sent from my iPhone using Tapatalk Can you install it at the ELT? Or does it have to be at the antenna?
Andy95W Posted December 20, 2017 Report Posted December 20, 2017 You may as well try it at the ELT first, since that would be easiest for a trial. I was theorizing that if there was a weird harmonic happening from the antenna through the cabling, putting the notch filter at the base of the antenna would block out more. Please keep us posted!
Joe Larussa Posted December 20, 2017 Author Report Posted December 20, 2017 19 minutes ago, Andy95W said: You may as well try it at the ELT first, since that would be easiest for a trial. I was theorizing that if there was a weird harmonic happening from the antenna through the cabling, putting the notch filter at the base of the antenna would block out more. Please keep us posted! Having it overnighted. Results this weekend. Fingers crossed
Brandontwalker Posted December 20, 2017 Report Posted December 20, 2017 14 hours ago, Joe Larussa said: Can you install it at the ELT? Or does it have to be at the antenna? The input side of the filter I used connected directly to the ELT and the Antenna connected to the output side of the filter.
Joe Larussa Posted December 20, 2017 Author Report Posted December 20, 2017 5 minutes ago, Brandontwalker said: The input side of the filter I used connected directly to the ELT and the Antenna connected to the output side of the filter. Just so I got this straight... The connection is made at the ELT in the back of the plane then to the cable that runs to the antenna? It can't be that easy. I don't need to remove the headliner and install at the back of the antenna?
Brandontwalker Posted December 20, 2017 Report Posted December 20, 2017 10 minutes ago, Joe Larussa said: Just so I got this straight... The connection is made at the ELT in the back of the plane then to the cable that runs to the antenna? It can't be that easy. I don't need to remove the headliner and install at the back of the antenna? You have it correct. It is that easy.
Joe Larussa Posted December 20, 2017 Author Report Posted December 20, 2017 Just now, Brandontwalker said: You have it correct. It is that easy. Things are never that easy for me! Lol If this this works you have a cold beer coming your way! 1
Joe Larussa Posted December 26, 2017 Author Report Posted December 26, 2017 On 12/20/2017 at 12:06 PM, Brandontwalker said: You have it correct. It is that easy. Well it looks like I owe you a beer! After shooting the same approach 20 times with a brief satellite loss each time, installing the notch filter at the ELT did the trick! Mooneyspace is awesome!! 3
Andy95W Posted December 26, 2017 Report Posted December 26, 2017 On 12/17/2017 at 5:54 PM, Andy95W said: I’d install a notch filter between the ELT antenna and the cable to the ELT. Simple BNC type connector. http://m.aircraftspruce.com/catalog/avpages/tednotch.php?clickkey=57768 Ummm, didn't I suggest a notch filter first? What about my beer?
Brandontwalker Posted December 26, 2017 Report Posted December 26, 2017 Well it looks like I owe you a beer! After shooting the same approach 20 times with a brief satellite loss each time, installing the notch filter at the ELT did the trick! Mooneyspace is awesome!! Glad you got it resolved Joe. I’ll hit you up next time I’m your way. Sent from my iPhone using Tapatalk
Joe Larussa Posted December 27, 2017 Author Report Posted December 27, 2017 6 hours ago, Brandontwalker said: Glad you got it resolved Joe. I’ll hit you up next time I’m your way. Sent from my iPhone using Tapatalk You bet!
Joe Larussa Posted December 27, 2017 Author Report Posted December 27, 2017 8 hours ago, Andy95W said: Ummm, didn't I suggest a notch filter first? What about my beer? Good as done!!!!!
