cnoe Posted June 14, 2017 Report Posted June 14, 2017 Has anybody flown their Mooney into the grass strip at Byrd's Adventure Center in NE Arkansas? I'll be landing there on Friday barring any significant rain in the area (none in the forecast). I've got a couple good reports on field condition but would appreciate any comments from other Mooney drivers (or any other first-hand knowledge). My J's been on grass a few times and I'm aware of the issue with tall grass and lower gear-doors. Slow full up-elevator taxiing is also understood. I'm just curious if there's anything else about this field (other than high terrain to the west) that may be of interest. Thanks!
steingar Posted June 14, 2017 Report Posted June 14, 2017 You're braver than I. One gopher hole and your aircraft is toast.
Stephen Posted June 14, 2017 Report Posted June 14, 2017 Looks like farmland to me; where's the runway?
The Other Red Baron Posted June 15, 2017 Report Posted June 15, 2017 (edited) That's more like West Central-ish Arkansas. If it was NE Arkansas I probably could have gotten someone to drive by and look for gopher holes... edit: I like how their promo video says "bush pilots only" at the end. Edited June 15, 2017 by revwatch
gsxrpilot Posted June 15, 2017 Report Posted June 15, 2017 I wouldn't hesitate to land my 252 on an established grass runway. Gopher holes are plentiful out in the pasture, but are certainly rare on regularly used, well maintained, grass strips. I know of several Mooneys based on grass strips and have been for years without incident.
Shiny moose Posted June 15, 2017 Report Posted June 15, 2017 Mooneys mostly do not have to worry about landing distances cause if you can meet take off performance limits from a runway you surely have enough room to land ( as long as your on speeds of course) remember every knot over speed adds 100' to your landing distanceThat runway is 1900 ft with a 600 ft rough cut extension, rising terrain, no runway condition reports, owner states on website "bush pilots only". That tells me rough surface, cause everything else about runway is printed. It's not something for me, No outs. But I would like to know how it goesSent from my iPad using Tapatalk
Mooneymite Posted June 15, 2017 Report Posted June 15, 2017 If the grass is dew covered/damp/wet, your braking coefficient is going to be poor. Even dry grass can be slippery.
moodychief Posted June 15, 2017 Report Posted June 15, 2017 Living in Arkansas, I have a lot of friends that fly into Byrd's... none in a Mooney. One friend has taken his Bonanza in there, another took his Seabee, and another took him and his wife in their J-3 cub (90 HP). They all said the same. The strip is a little bouncy but not bad. Just don't Plan on using the 600 feet as it is really rough. The J3 was on a very warm day and he mentioned he didn't know if they were going to clear the trees as they were close to gross. I would go in as light as possible. Fuel after leaving as there are a couple of fields with fuel within 10-15 minute flight.
