Hi,
does anybody know where I can find those screw in type covers for the bulbs that sit under
the glareshield for instrument panel lighting. It seems that they are not listed in the parts catalog ...
Emmet
Emmet,
I had a few of them jump out and scare me while in flight.  You may find some Under the seat!  Foot in mouthLOL
Actually you may want to look at the part number for the floor gear down indicator light.  I think they may be the same.  Just going by memory.
  • 2 weeks later...
Emmet,
I was successful in getting some from Dugosh in Kerrville.  They were about $47/each.  Good luck.
whaoo... that's a bargain Cry
... at least I found the partnumber in the parts catalog - chapter fuselage  53.10.04 - strange ...
Thanks everybody for the help !
Emmet
What is it you are looking for?
There are several panel screw in type panel lights available from aircraft spruce....Some now with LEDs...
Key word is "post light"
Keep in mind the dimmability of LED, one other old style incandescent bulb must be in the ciruit also...
Of course the picture did not come through......
1. MODEL 70844 SERIES LED POST LIGHT
The model 70844 series are LED (Light Emitting Diode) instrument post Light assemblies. They are designed to illuminate the instrument panel, and function as instrument mounting bolts.
  • 4 weeks later...
I recently tracked these down and replaced them with the LED version.  Here is the info:
Doug
MIDGET FLANGE BASED LED-Aircraft Spruce
Midget Flanged Based LED, T1-3/4 (5mm) Energy-Saving Miniature Lamp
A direct LED replacement for Midget Flanged Based miniature incandescent lamps. Many colors available. Voltages from 5V-28V AC or DC, Replaces lamp # 328, 345, 350, 7335(5/6V), 330, 382, 394 (12/14V), 327, 376, 387 (24/28V)
Description
Part No.
Price
Buy
MIDGET LED REPL LAMP T1-3/4
11-08478
$4.65
