Oldguy Posted January 2, 2017 Report Posted January 2, 2017 Has anyone else experienced their iPad "sticking" in one presentation after the IOS 10.2 upgrade? I have now had multiple occurrences of mine sticking in portrait and landscape since the last IOS upgrade. While it has not happened while I was in flight, it is irritating when it does it on the ground. The only solution I have found is to power off and back on (reboot). The wife's mini also shows the same symptoms. Current iPad is iPad Air, 64 GB, IOS 10.2., WI-FI and ATT cellular. Wife's is iPad mini Retina 64 GB, IOS 10.2, WI-FI only. Thanks. Quote
Hector Posted January 2, 2017 Report Posted January 2, 2017 Yes, it has happened a couple of times recently. I did not make the connection to the IOS update. I thought it was just my iPad acting up. Had to turn it off as you did. Sent from my iPad using Tapatalk 1 Quote
carusoam Posted January 2, 2017 Report Posted January 2, 2017 Not seeing it on an iPad Air with IOS 10.2... Used all day every day... Best regards, -a- 1 Quote
ArtVandelay Posted January 2, 2017 Report Posted January 2, 2017 Might have something to do with what apps you are running, check for commonality between you and your wife. I've not seen it either. 1 Quote
