Santa brought a new toy, see attached photo for JPI730 placement.  Wasn't absolutely sure it was going to fit until unit was received - only thing moved was the go around button had to go down about 1/2".  Installed only with oil temp and oil pressure options, as am happy with the horizon digital tach and shadin mini-flow.
Installer made a call to local FSDO to confirm that indeed the only certified replacements are for the EGT/CHT functions on these units, confirming others' conclusions on mooneyspace.
For the money, both for the unit and the installation, the 730 is a great deal.  The original GEM 602 installation that it replaces cost almost as much, and that was in (1984?) dollars.  So far, the unit seems to work as advertised.
Oh, one installation note: the mounting 'collar' that goes on the inside of the panel to hold the unit in had to be pointed to the right (and reached from the side by removing the sl40), as the screw to tighten the collar could not be reached from below due to the switches/structural bars).
If one was not interested in having anything as certified for replacement would it be feasable to buy and install the 740 or is that truly just for experimental?
Mike
Excerpt from STC #SA3586NM from JPI web site, 2nd page:
"Limitations and Conditions - continued
Cylinder head, oil, [...] and/or exhause gas temperature, [...] instruments required by the original type design, or if required by other FAA approval, must remain installed and operable."
