Guitarmaster Posted January 22, 2016 Report Posted January 22, 2016 A question for you all... I am thinking about making a custom carbon fiber overhead panel. it would include all the vents, speaker and warning buzzers of course. In addition I was thinking of adding led dome lighting with reading lights and baggage light. This is the question. Since this is interior panels only, would it need to be STC'd or could I just do it assuming it meets flame standards? Quote
KSMooniac Posted January 22, 2016 Report Posted January 22, 2016 You can make your own easily and be within the regs. Interior stuff is covered under owner-maintenance generally speaking. Just pic good materials and do your own burn test before you get too far down the road just to be sure. Quote
HRM Posted January 22, 2016 Report Posted January 22, 2016 Contact Bruce Jaeger, he came up with plastic panels and paint for his Spatial Interior system and I believe he sells individual parts. 1 Quote
capthaak Posted January 23, 2016 Report Posted January 23, 2016 The Jaeger interior is STC'ed. The question lies if you're just building your own or looking to sell. I'm leaning towards the answer from the FAA would be STC required. Sent from my iPad using Tapatalk Quote
Brandontwalker Posted January 23, 2016 Report Posted January 23, 2016 A question for you all... I am thinking about making a custom carbon fiber overhead panel. it would include all the vents, speaker and warning buzzers of course. In addition I was thinking of adding led dome lighting with reading lights and baggage light. This is the question. Since this is interior panels only, would it need to be STC'd or could I just do it assuming it meets flame standards? Make 2 while you're at it. My overhead vents are broken to pieces. Called plane plastics earlier this week and had a rather snarky rep inform me that I am out of luck. My plan was to remove what is left of the vents, fiberglass over the openings and install eyeball vents. Your plan sounds better, but well beyond my skill set. Sent from my iPhone using Tapatalk Quote
HRM Posted January 23, 2016 Report Posted January 23, 2016 26 minutes ago, capthaak said: The Jaeger interior is STC'ed. The question lies if you're just building your own or looking to sell. I'm leaning towards the answer from the FAA would be STC required. The STC covers the Spatial Interior panel retrofit--this is hands down the best thing you can do with your vintage Mooney. Bruce buys the plastic from a company that supplies the companies who do the interiors of the airliners. The roof panels are just sheets of plastic that are spray painted and cut to fit. This any owner can do. Bruce has done the checking already for burn rate, etc. Quote
CDF219 Posted January 23, 2016 Report Posted January 23, 2016 I did not do the vents they were too brittle and thought Id damage them and then be SOL.... 1 Quote
Yetti Posted January 23, 2016 Report Posted January 23, 2016 Seems like some reinforcement on the old panel from the back side and some epoxy and carbon fiber cloth and some vacuum bagging and owner supplied parts log book entry and you should be fine. Only if you are selling would you need a PMA or STC. 1 Quote
Guitarmaster Posted January 23, 2016 Author Report Posted January 23, 2016 I did not do the vents they were too brittle and thought Id damage them and then be SOL.... That looks very nice! I was thinking of removing the air vents all together and replacing them with eyeball vents. Sent from my XT1254 using Tapatalk Quote
Andy95W Posted January 24, 2016 Report Posted January 24, 2016 On January 22, 2016 at 4:47 PM, Guitarmaster said: A question for you all... I am thinking about making a custom carbon fiber overhead panel. it would include all the vents, speaker and warning buzzers of course. In addition I was thinking of adding led dome lighting with reading lights and baggage light. This is the question. Since this is interior panels only, would it need to be STC'd or could I just do it assuming it meets flame standards? I think this probably fits the "Owner Produced Parts" definition to a 't'. 1 Quote
Guitarmaster Posted January 24, 2016 Author Report Posted January 24, 2016 All the replies confirm what I thought to be true. Now to find time to make the mold.... Quote
HRM Posted January 24, 2016 Report Posted January 24, 2016 1 hour ago, Guitarmaster said: All the replies confirm what I thought to be true. Now to find time to make the mold.... Why not contact Plane Plastics? They have what I believe is the original mold for the roof panel(s). Might be able to make a deal. Worst case scenario is that they say no. Quote
jamesm Posted January 24, 2016 Report Posted January 24, 2016 I am not sure that you would be saving any weight by going to carbon fiber, however you would get much more strength but that is about it. I have been told that when it comes to these interior pieces, it tends to be a grey area when come to the FAA. Since many interior pieces add no structure value to the air frame, about the only thin I am aware of would raise concern the meets the FAA's flammability requirements. James '67C Quote
Guitarmaster Posted January 24, 2016 Author Report Posted January 24, 2016 3 hours ago, HRM said: Why not contact Plane Plastics? They have what I believe is the original mold for the roof panel(s). Might be able to make a deal. Worst case scenario is that they say no. Basically because I love making custom stuff. The Plane Plastics part is fine, but I would like to "modernize" it. I know there is a continent of guys out there that think a vintage plane should stay original. I think that has it's place, but I'm going for more, "resto-mod" look. I'm doing the same with my '68 Cougar. Gone are the days of resorting to original to retain value. Resto-mod cars are worth considerably more than stock. I think it is really more of a generational thing. I probably should have bought an experimental. 2 Quote
HRM Posted January 25, 2016 Report Posted January 25, 2016 1 hour ago, Guitarmaster said: Basically because I love making custom stuff. The Plane Plastics part is fine, but I would like to "modernize" it. I know there is a continent of guys out there that think a vintage plane should stay original. I think that has it's place, but I'm going for more, "resto-mod" look. I'm doing the same with my '68 Cougar. Gone are the days of resorting to original to retain value. Resto-mod cars are worth considerably more than stock. I think it is really more of a generational thing. I probably should have bought an experimental. Yes, I resemble that remark, sorta (...a continent of guys out there that think a vintage plane should stay original). I went the 'resto-mod' route and did it the way I would have wanted Mooney to do it back in the day. I thought you had to stay to the original part and it's components; i.e., the light projectors, rheostats, weird air vents, etc. Frankly, I just liked "updating" mine with paint and crack repair. If you plan to go whole hog, then go for the eyeball vents and LED lamps. Also, lose the speaker. Frankly, if you do all that you may get into 'issues' later. When I saw this post I just assumed (yeah, I know) you were just wanting to carbon fiber the existing panel. As for the Cougar--you dog! I had one back in HS...those were the days. 1 Quote
Marauder Posted January 25, 2016 Report Posted January 25, 2016 3 hours ago, HRM said: Why not contact Plane Plastics? They have what I believe is the original mold for the roof panel(s). Might be able to make a deal. Worst case scenario is that they say no. Basically because I love making custom stuff. The Plane Plastics part is fine, but I would like to "modernize" it. I know there is a continent of guys out there that think a vintage plane should stay original. I think that has it's place, but I'm going for more, "resto-mod" look. I'm doing the same with my '68 Cougar. Gone are the days of resorting to original to retain value. Resto-mod cars are worth considerably more than stock. I think it is really more of a generational thing. I probably should have bought an experimental. Hope that Cougar has the 390 with a nice Holley on top. Vrooom, vroooom Sent from my iPad using Tapatalk Quote
bonal Posted January 25, 2016 Report Posted January 25, 2016 8 minutes ago, Marauder said: Hope that Cougar has the 390 with a nice Holley on top. Vrooom, vroooom Sent from my iPad using Tapatalk A 351 Cleavland with a top loader much better fun than the 390 Quote
M20F-1968 Posted January 26, 2016 Report Posted January 26, 2016 For anyone redoing the ceiling panels and good with composites, I have the left and right ceiling panels from an Ovation which I did not use. I bought them for my airplane (a 1968 F) but then got my hands of a full 1998 Ovation interior so I ended up with 2 sets. One set was modified to fit into my F model. The other set was cut to length to fit into the mid-body length but was not otherwise altered. These may be a good starting point for anyone wanting to redo the ceiling of a vintage Mooney. The fiberglass is easy to work with and the panels can be made to fit what you need. It is best to start with a large panel and alter to fit the windows. Give me a call if there is any interest. Cell (617) 877-0025 or e-mail: john.breda@gmail.com You can see the end result on my Album pictures at M20F-1968 John Breda 1 Quote
Guitarmaster Posted January 26, 2016 Author Report Posted January 26, 2016 On January 25, 2016 at 8:21 PM, Marauder said: Hope that Cougar has the 390 with a nice Holley on top. Vrooom, vroooom Sent from my iPad using Tapatalk Nope... It's a 351W. Holly 750. Not sure of the manifold. Headers into duals with Flowmaster 40's. 9" Rearend. 2500 stall racing TC. Built c4 tranny. 224/51 cam makes it fairly aggressive but still streetable. It has not been on a dyno, but the specs show 400HP/396TQ. I didn't build it. I bought it off a widow of the guy that built it for a great price. 1 Quote
