My Mooney does not have Jack Point to replace the tie downs.
Is there something else to use in place ?
meaning from cost effective point of view .
carl
Lasar is the is known source for their aerodynamic jack point and tie down.  One of the nicest improvements for all Mooneys...
lasar.com
I don't see it on their site.  Sheri is the person to talk to.
best regards,
Edited by carusoam
Jack points?
I just went to the hardware store and bought some bolts "long enough", fitted them with a large washer and a jam nut.  I actually have two sets (since they were so expensive).  One set I left the head on, the other set I ground to a nice rounded point.  My jacks seem to work equally well with either set.
However, DO NOT USE this idea.  I'm one of those troglodytes who ties the tail to my hangar floor and risks pulling the tail off.  Who knows what my home-made jack points will do!
Except the Lasar tie down gets bent with Meyers hydraulic jacks because the jack is bigger in diameter.
1/4 28 bolts and a stack of flat washers , there problem solved for 6 bucks...
I installed this with washers and a lock washer and just leave them in all year round.  A light touch with a wrench and it unscrews easily to install the tie down rings.
Just put the LASAR point on, they were 45 the pair. Quite cheap in respect to aircraft. I have jack house jacks, so they hopefully will not bend.
I second this. I always remove the tie downs when jacking the plane for this reason.
The Jack House jack will not bend the tie down because it has a smaller diameter cylinder, however they are taller than Meyer and therefore don't always fit under the wing.
Thank you all for you input .
At first I said I'll get the LASAR tie downs and jack point comb and be done with it.  So I went to their web site and was extremely tormented. I don't think it is a very user  friendly site. It took me a hard time to find the item. Then I tried to order it and i can't do it online. I'm guessing you have to call their sales person, parts dept.  So I called, darn-it it's Saturday,closed no answer. Now i'm a little peeved!
I take a break,I go out to the grocery store, when I come back and check this blog  I see Mooneymite's and Alan's post , yes!, trip to the depot and I'm going to be set.
Only difference is  my tie down bolt size is a 5/16 -18
thanks
carl
Lake Aero web site is not really updated and it's not like Aircraft spruce etc all about buying stuff on line. It's a Monday through Friday shop but if you call they will get you whatever you need shipped out fast. Also, if you just need information they know Mooney's as well as anyone and will take the time to answer your questions.
I spent $8.48 at home depot because somethings are in multiples packages.
 I attached pictures.
These are simulations only, my wing is not made of Styrofoam, measurement are estimated , drawing is not to scale, I have only posted this as a learning experience and make no recommendations .
carl
Edited by carl
thanks. I just bought mine. $30 is a reasonable price. I've homemade some in the past as well. I don't usually think to save them though.
-Robert
When you get a chance call Lasar and talk to Sheri, anyway...
She is like the gate keeper of the Lasar organization and is able to help get a Mooney pilot what he needs or at least point you in the right direction. Sometimes she has a post around here as well.
By the way, nice mock up and drawings!
I'll continue using the official Mooney Jack points.  It would be embarrassing to explain that your plane fell off my homemade jack points and both wings need repair. Ouch!!
What material are the "official" jack points made from? SS? 303? 304? Grade 8 is heat treated and pretty strong
but then again I go old school and use the tail ring also (but not on big engine Mooneys:-) Your milage may vary.
420 / 440 is easier to find, and machines much better. It's also magnetic, so you can pick them up,with a retriever if you drop them so,we here inconvenient.
Sometimes its not the money , but the challenge of being a cheap bastard....That being said , every Mooney I have ever owned , had the Lasar jack tie downs installed.....Its just a great Idea.....
