Marauder Posted July 22, 2015 Report Posted July 22, 2015 Hi All -- I have a friend selling his 1989 J (a real cream puff) and a potential buyer is asking what it would require to increase the useful load to 2,900. Does anyone know if the modification is still available and how to obtain it? Sent from my iPad using Tapatalk Quote
KSMooniac Posted July 22, 2015 Report Posted July 22, 2015 I might have just answered his question on the email list. You'll have to go to the TC data on the FAA website and make sure his S/N is in the eligible range. I believe it points to a Mooney drawing for compliance, and it might just be a re-screen of the airspeed indicator and maybe POH revision. Any MSC should be able to do it if the plane is eligible, and it shouldn't be crazy money. 1 Quote
ArtVandelay Posted July 22, 2015 Report Posted July 22, 2015 Search for this thread: Gross Weight Increase STC for J's Started by Jeff_S , Jan 06 2010 02:56 PM 1 Quote
Marauder Posted July 22, 2015 Author Report Posted July 22, 2015 I might have just answered his question on the email list. You'll have to go to the TC data on the FAA website and make sure his S/N is in the eligible range. I believe it points to a Mooney drawing for compliance, and it might just be a re-screen of the airspeed indicator and maybe POH revision. Any MSC should be able to do it if the plane is eligible, and it shouldn't be crazy money. Thanks! I think he did ask this as well on the MAPA email list. BTW -- anyone looking for a really sweet J, you should check this one out. N1075C Sent from my iPad using Tapatalk Quote
KSMooniac Posted July 22, 2015 Report Posted July 22, 2015 Well, I'm curious again and refreshing my memory. Hopefully his S/N is between 1686 and 3200. Here is the TC link: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/cd54a24fc81bae1c86257df20054b12c/$FILE/2A3_Rev_56.pdf Search down to M20J section and you'll find this: S/N 24-3201, 24-3218 thru 24-TBA, and 24-1686 thru 24-3200, 24-3202 thru 24-3217 when c/w MAC dwg. No. 940071 and insertion of applicable AFM supplement - 2900 lbs. gross weight. C.G. Range (+45.0) to (+50.1) at 2900 lbs. (Landing gear extended) (+43.8) to (+50.1) at 2740 lbs. (+41.8) to (+50.1) at 2470 lbs. (+41.0) to (+50.1) at 2250 lbs. or less (Straight line variation between points given). Retraction moment 615 in. -lbs. I don't remember what is in the DWG #940071 but it isn't much. Doing the Encore conversion on a 252 (+230 lb GW) changes significant hardware. 1 Quote
Marauder Posted July 22, 2015 Author Report Posted July 22, 2015 Well, I'm curious again and refreshing my memory. Hopefully his S/N is between 1686 and 3200. Here is the TC link: http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/cd54a24fc81bae1c86257df20054b12c/$FILE/2A3_Rev_56.pdf Search down to M20J section and you'll find this: S/N 24-3201, 24-3218 thru 24-TBA, and 24-1686 thru 24-3200, 24-3202 thru 24-3217 when c/w MAC dwg. No. 940071 and insertion of applicable AFM supplement - 2900 lbs. gross weight. C.G. Range (+45.0) to (+50.1) at 2900 lbs. (Landing gear extended) (+43.8) to (+50.1) at 2740 lbs. (+41.8) to (+50.1) at 2470 lbs. (+41.0) to (+50.1) at 2250 lbs. or less (Straight line variation between points given). Retraction moment 615 in. -lbs. I don't remember what is in the DWG #940071 but it isn't much. Doing the Encore conversion on a 252 (+230 lb GW) changes significant hardware. His serial number is 3126. Looks like he is golden. Thanks for the quick response. Sent from my iPad using Tapatalk 1 Quote
Parker_Woodruff Posted July 22, 2015 Report Posted July 22, 2015 Re-screening of the airspeed indicator and new POH paperwork was what was required when I did this to my 1990 M20J-AT. Quite a nice upgrade. Watch density altitude at the higher weight and plan departures accordingly. 2 Quote
smccray Posted July 22, 2015 Report Posted July 22, 2015 +1 I did the gross weight upgrade a couple years go. It was a piece of cake. Maxwell could tell you what it will cost- it's not a big number as far as upgrades go. 2 Quote
