Copied this from a friend of mine on another forum. Evidentlly the sat based ADSB will only work with 1090 and not UAT 928 frequencies. How long until UATs are told to convert to 1090 xponders?
Although this is from 2012 I've never heard of it before.
Aireon Will Add ADS-B Receivers to Iridium Satellites for Worldwide Aircraft Surveillance
by Matt Thurber
- July 4, 2012, 12:15 AM
A planned joint venture by Iridium Communications and Nav Canada promises to offerworldwide ADS-B-based air traffic surveillance services using the upcoming Iridium Next satellite network. Iridium said last year that it was considering adding an ADS-B payload to its Iridium Next satellites, which begin launching in 2015 and will be completed in 2017. The Iridium-Nav Canada joint venture, called Aireon, will add 1090ES ADS-B receivers made by Harris to each of the 66 satellites (and backups) destined to form the Iridium Next constellation. Iridium is aware that its choice of the name Aireon sounds the same as supersonic business jet developer Aerion’s moniker when spoken, and in print is only one transposed letter different, but feels that the name “accurately reflects the vision and strategy of the company and works well with various cultures worldwide,” according to an Iridium spokeswoman. Iridium filed the Aireon trademark with the U.S. Patent and Trademark Office on December 1 last year.
The low-earth-orbiting Iridium satellites will offer worldwide coverage, including polar regions, and with the ADS-B payloads “will provide complete visibility to all aircraft everywhere,” according to Iridium, “helping ANSPs [air navigation service providers] decrease inefficiencies. This new capability will extend the benefits of current radar-based surveillance systems, which cover less than 10 percent of the world, to the entire planet.” Aireon is expected to become operational in 2018, two years before the FAA’s ADS-B out equipage mandatetakes effect.
Benefits of Aireon include fuel and emissions savings from optimal routing, more closely spaced traffic and extended operational safety provided by the ability to track ADS-B/Iridium-equipped aircraft anywhere in the world. “ANSPs will be able to introduce active ATC to wherever airlines fly,” said Nav Canada president and CEO John Crichton. “We know first-hand how important it is to find a solution in areas not reachable by traditional means. Airplanes must fly on predefined routes that force use of inefficient altitudes and do not take advantage of constantly moving jet streams. We’ve been working for years to find ways to improve remote and oceanic travel. Instead of limiting [coverage] to ADS-B surveillance around the edges of oceans, we will be able to extend [coverage] across oceans, starting with the North Atlantic. ANSPs will be able to introduce active ATC to wherever airlines fly, with all the benefits that will bring.”
While general aviation was never mentioned during the Aireon press conference on June 19, the Iridium spokeswoman told AIN, “GA operators can certainly use the benefits of Aireon as long as they are equipped with 1090 MHz ADS-B equipment. Any airplane having this equipment on board will be visible to controllers and will be provided better services.”
ADS-B ground stations are being installed all over the world and are set to cover the entire U.S. next year, but there is no way to provide surveillance over oceans or remote areas that lack radar coverage without using satellite communications. Aircraft are already broadcasting GPS-derived position information over satellite networks on oceanic routes, but the Aireon system adds the ADS-B ground station technology to a worldwide satellite network, thus making it possible to deliver comprehensive surveillance data to ANSPs that plan to work with Aireon.
“The capability that Aireon will bring to navigation is substantial,” said Don Thoma, who will be president and CEO of Aireon. “This extends the reach of ground stations that are being built today.”
I was thinking in terms of mission creap. Someone will propose that there is no need for a ground based system to recieve 928 UAT if the 1090 system in space is available. So then we have "bye bye UAT".  Mission creap always happens. Then they (FAA) don't have to absorb the cost of the IN side either as most of that is UAT only and it WILL go away.
Typo on the 928
The IN was an after thought to make the system edible for GA. Without the IN on UAT (not enough space on 1090 for the IN side of the equation) there is no reason other than Mandate for GA to have ADSB. The entire system is already upside down in cost benifit per the government not me. They are "giving us" something (the IN side) to make us want to equip.
You can debate the "benefits" all you want but most everything offered on the IN we already have with other venues.
If you want fake TCAS on your pad  then this is for you.
The entire systen was designed form the inception from the top down. Large A/C, big airports then down the ladder to bring us in.
Right now they can't even do an end to end test. They needs LOTS of us to equip so they can finalyze design and testing.
