  • 3 weeks later...
Sure do! LASAR has them. They say "EFIS Master" and are black with white lettering. 8 amps rating, these are the E-T-A style. If you need a white cover with black lettering that may be a bit harder, unfortunately.
Lake Aero Styling and Repair www.lasar.com
I'm in the process of an Aspen install also. I told my installer I didn't want one of those metal toggle switches and preferred a white rocker be installed next too all the others. This might be a better idea. Mooney rockers are expensive; had a red one installed for my electronic ignition and was charged about $250. But it looks good.
Here is a picture. The EFIS Master is 8 amp, E-T-A style. The RADIO Master switch next to it is a Sensata Klixon TC-20 style switch....I am trying to find a black RADIO Master E-T-A so they match. When I do, all my Klixons will be sold.
post-7205-0-47944200-1421995018_thumb.jp
How did you get the E-T-A and Klixon to work on the same buss? Aren't the spades located in a slightly different spot on each style?
I emailed my installer. That's what I want. Looks great. Thanks for sharing!
